Gruppe-s 60 mm panel help
Old Jun 10, 2006 | 04:59 PM
2StepsAhead's Avatar
Anyone else have any fitment problems? The two gauges to the right fit fine but the gauge closest to you does not sit flush in the pod causing the gauge to not really snap in.
Is there any trick I'm missing to put the gauges in tight and secure? I'm afraid on a hard launch or a big bump one might come lose.
Old Jun 10, 2006 | 05:01 PM
EVIL MR's Avatar
Oh man, I was just about to order me a set.
Old Jun 10, 2006 | 05:32 PM
Well I'm coming up pretty empty handed for install tips on this, I guess everyone else's was fine but the gauge closest to me does not fit snug in there at all. It seems its bent or something cause I push the gauge in like the others, it "snaps" into place and then pops back out once I remove my hand from it.
Old Jun 10, 2006 | 05:51 PM
outsider's Avatar
is this the new version of their panel?
Old Jun 10, 2006 | 06:02 PM
Just got it brand new about a week ago so I assume it is.
Old Jun 10, 2006 | 06:16 PM
outsider's Avatar
ok, because the older one had issues
I dont own their new panel (I have a custom panel), but perhaps the issue is with the rear portion of the gauge perhaps being too large?
Did you check to make sure the rear portion of the gauge isnt bumping against the radio bracket? I had to trim mine just a bit.
Old Jun 10, 2006 | 09:21 PM
memo3's Avatar
I have both new and old one and they fit just fine.
Old Jun 11, 2006 | 12:23 AM
It was touching the front of the panel (where it curves) so I trimmed it a little, we wanted a really snug fit so I didn't use the foam tape I put a zip tie behind and its good for now.
Old Jun 11, 2006 | 12:54 AM
outsider's Avatar
old did not fit fine which is in part why they came up with this new version which uses the factory clips
alot of people had issues with it fitting so-so
cool
Old Jun 11, 2006 | 01:04 AM
revvin9k's Avatar
Old Jul 9, 2006 | 10:40 AM
EnJaNir's Avatar
rev...I'm I just got my panel and did some test fitting and I'm curious if you needed to trim the stock radio support at all for the far right gauge. It doesn't seem like there is much clearance to me..but I dont have any idea how deep the gauge itself is.
Old Jul 9, 2006 | 03:04 PM
wj4's Avatar
wj4
i have the gruppe s panel..no fitment at all. and i used that strip of felt included in the defi guages to secure them around for a bit more snug fit
Old Jul 9, 2006 | 06:16 PM
MrFairlady's Avatar
yeah..mine fits great.
I even was able to put a 52mm AEM UEGO gauge in mine.
Old Jul 9, 2006 | 06:28 PM
6-speed's Avatar
Here's a tip.
My Defi BF gauges didn't fit well into the Gruppe-S panel opening; the housing was loose and had too much play.
I tried the felt strip that Defi provided bit it was too thick and de-laminated when I tried installing the gauge into the panel.
So I used some masking tape, the blue 3M masking tape used for painting, and stuck it to where the gauge housing touches the inside lip of the panel.
It was just thick enough to give me a tight seal.
BTW, I used the masking tape because it easy to remove and doesn't leave any residue.
Good luck.
Old Jul 10, 2006 | 07:09 PM
scubaEVO's Avatar
looks good
mullen
Nov 6, 2015 11:18 AM
humpevo311
Sep 20, 2015 03:31 PM
Supergoslow
Apr 11, 2015 04:18 AM
Kevin Knight
Jul 12, 2011 08:42 PM
06MRV8Killer
Sep 7, 2008 02:52 PM
