LED map + dome lights
So I found this site online that makes LED lights for the interior of our cars.
www.leddomelight.com -- anybody seen these?
I bought the map + dome lights and let me just say they are sweet.
It is so Bright.
It is like HID's for the interior. makes it light up bright white instead of the dingy yellow light look.
Thinking about getting the trunk and license plate led's also.
Super easy to install and fit like a glove.
Just take old bulb out and plug these in , that easy..
Map light came with 3 different sets of led's, so all bulbs are switched to led's.
And dome light was one big panel of like 12 leds.
Definately worth it.
So just throwing out the info... ltr..
It is so Bright.
I got LEDs in my dome too... but at the time they didn't make any that fit (and were bright enough) so I went to radio shack and bought 16 12v leds and put em on a pcb, wired up the diodes and resistors... but since they got a kit now I think im gonna check those out. Definately worth it.
SICK9, do those LEDs dim off or do they just turn off?
Link works fine for me , try again maybe or refresh it...
I spoke to Matt, very nice guy, really helpful, and very fast shipping..
Took me all of 5-10 minutes to install
Eva06 - They dim slowly just like the old bulbs.
I have those too. I have LED white & blue.
SICK9
How did you install the LED light in front? when you removed the bulb in front, did you remove the whole plastic covering it? I cant seem to pull them out, thats why I only have LED in the middle.
SICK9
beast - you just pop the map light cover off with a small flathead and unplug all 3 bulbs, then you plug each led set in it's place, then put them in the space where the orig. bulbs were, -- very easy.
Each led pack is made to fit perfectly in the space.
The map light set comes with 2 triangle shaped pieces for each map light and then a square shaped piece for the center map light.
can only go in one way, so it's easy..
The Middle led pack[dome light] fits same way except it's only one big led pack.
and yes it was 75$ for all the whole set.
Map light and dome light set consists of 4 different led packs,
3 for the map lights, and 1 for dome light...
They are very bright, pics. dont do it justice, taken w/ no flash...
