My New BBS RE's
Couple ?s -
1. Did you have to roll the fenders to get the wider tires on there?
2. If you didn't have to roll the fenders, is the offset enough that there is no rubbing?
Looks great !!!
Looks great !!!
The offset is a pretty aggressive one. +24 on a 9.5 wheel. I know there are a few people with Volks in a +22 with the same tire size and I have seen +15 with a much smaller tire. The front clears these with no problem.
These clear the brakes with absolutely no issue. In fact there is probably about 15mm from the wheel to the front caliper at its closest point.
I really do need to get better pics... I think these wheels look amazing. Better then I had imagined. I need to capture different angles to get the concavity of the wheels as well as the overall stance.
Price, these will set you back the same amount as a set of Volk RE30's in the same size 18x9.5. In this size, wheels are produced by BBS Japan and are forged.
