HID with HID FOG's
Old May 11, 2010 | 06:31 AM
JustJeff's Avatar
HID with HID FOG's
Anyone have pics of their HID setups with HID Fog's?
I am looking into matching my normal Fog Bulbs color to my HID'S. I dont think you can do this so maybe Adding HID'S that match the Stock HID's is the way to go.
Thanks.
Old May 11, 2010 | 06:40 AM
erald01's Avatar
you def going to blind people, i already get flashed with lights from other cars when i have my stock HIDs and the yellow fog lights on
Old May 11, 2010 | 12:24 PM
Evoixjohn's Avatar
here's my set-up stock hid and 3000k hid
Old May 11, 2010 | 01:17 PM
tim85851's Avatar
i rock 6000k hid since my stock hid's burned out...and hyper yellow nokya fogs (non HID and only cost $15 shipped on ebay)...
Old May 11, 2010 | 01:19 PM
EvoCop's Avatar
Bargin shopper
Good stuff!
Old May 12, 2010 | 06:07 AM
JustJeff's Avatar
Thanks for the pics.
I dont wan't to go with the 3000k yellow look, so trying to find similar fog HID's or maybe fog bulbs that are a similar color to the Stock HID low beams.
Old May 12, 2010 | 06:10 AM
SicLanEvo's Avatar
I have 8k bulbs in my hids and 3k hids in my fogs. I used to have the nokya yellow fogs which actually put down more light then the hids I have. I will be changing my whole setup in the next month or so and i will try to post up some pics.
Old May 12, 2010 | 08:47 AM
blue_machine's Avatar
See what you really want to do is go out and get three sets of 10000k hid bulbs and switch the low beams,fogs and high beams and re wire your lights so all three lights stay on when you click your high beams on you could prolly give the other people driving a flash burn like from welding lol
Old May 13, 2010 | 06:08 AM
JustJeff's Avatar
Yeah! Look at my lights! its like starring at the Sun!
Old May 13, 2010 | 06:26 AM
Jamdown's Avatar
fwiw I have used the hoen xenonmatchs and they are very close to the stock HID color www.hoen-usa.com
That being said, I got ALOT of people flashing me when I had them on. To them all they see are an extra pair of lights on that look like highbeams...When I flashed em back with the real highbeams they didn't flash anymore though lol
It was mostly b/c of this why I went with the hoen endurances (yellow)...NO flashes yet and I've had em for a long time now
Old May 13, 2010 | 06:47 AM
SicLanEvo's Avatar
10k is not that bright, its more annoying than anything. if your looking for light output go with 6k. after 6k the light output goes down and color changes more. I dont get flashed with my setup because my hids and hid fogs are aimmed properly.
Old May 13, 2010 | 02:27 PM
fugiwara's Avatar
yellow fogs are outdated, OEM like HID fogs is the way to go.
Old Nov 3, 2012 | 01:14 AM
benIX's Avatar
Quick question guys I have Evo 9 SE which has low beam HID from the factory. I got 3000k HID kit when I plug them into the stock fog light harness they don't turn on. Are the 06 Evo 9s not suppose to run HID for fog lights? Or do I need to do something else in order to make it work? Thanks in advance guys
Old Nov 3, 2012 | 05:51 PM
krispytapa's Avatar
I believe the stock HID color is 4300k. Foglight color is a warm yellowish color. I don't think there's a matching warm HID color. The closest would be 3000k which isn't exact and is more bright yellow.
JDM headlights with stock HID 4300k headlight and stock NON HID fogs
Old Nov 3, 2012 | 05:55 PM
krispytapa's Avatar
benIX; You may have the positive/negative wires switched and may have blown a fuse. Check the fuse, switch the positive/negative wires and try again.
keepersway
Nov 30, 2016 08:32 AM
lookitznite
Aug 25, 2011 06:42 AM
yorT
Oct 19, 2010 06:57 PM
omniprobe
Jun 5, 2010 06:46 PM
lookitznite
Sep 7, 2009 12:49 PM
