JDM Red Evo 7
Hey,
Thought i'd post up because I use these forums quite a bit to look at vendor parts and reviews on them and has been quite helpful!!
Car is mainly aimed at street use and light track work, its my daily driver to work everyday and yes I live in Australia. Imported the car straight from Japan with 88,000kms through a reputable broker.
Need a new thread on a new forum to keep track of parts/installation etc
Dyno print out is on a hub dyno, and power is quite low at the moment as something is restricting the power. Tuned @ 1.5 bar.
At the moment car is in bits, radiator seems to have a split in it - spewed out coolant everywhere. Other issues i'm having are gearbox syncro's are a little worn and warm start issues with injectors. Other then that I love it!!
Engine
K&N Pod Filter
AVO Cast Intake Pipe
8MR BOV
X3E Polished Upper Intercooler Pipe
X3E Lower Intercooler Pipe
GTPumps/Zage Dump Pipe (I believe this is Titek o2 housing in US)
SMB 3" Front Pipe
Tomioka 3" Hi Flow Cat
Tokyo Motorsports 3" Straight Mandrel Bent Catback Exhaust
Okada Plasma Direct Coilpacks
NGK Spark Plug Leads
NGK Iridium IX Spark Plugs (BPR8EIX)
Cusco Oil Catch Can
GTPumps 18G Titanium Wheel "Evo 9 TME" Turbo - 10.5 Hotside TD05
PTE 680cc Injectors
Walbro Fuel Pump
Trust Profec B Spec 2
Apexi Power FC (Non D-Jetro)
Blox Radiator Mounts
Ralliart Front Engine Roll Stopper
Beatrush Radiator Cooling Panel
Samco Radiator Hoses
HKS Oil Cap
Trust Radiator Cap
Carbign Craft Carbon Spark Plug Cover
MonsterSport Exhaust Manifold Heatshield
Driveline & Handling
Trust Type S Coilover
MonsterSport Front Strut Bar
Whiteline Rear Strut Bar
Whiteline Front 26mm Swaybar
Whiteline Rear 24mm Swaybar
Ralliart Shifter Bushings
HEL Braided Clutch Line
Footwork & Brakes
18 x 9.5 +22 Rays Gram Lights 57 Optimise Time Attacks
Kumho Ecsta KU31 255/35/18
Front & Rear Guards Rolled
Rays Black Lug Nuts
DBA 4000 Slotted Rotors All Around
Elig 2021 Brake Pads All Around
HEL Braided Brake Line
Interior
HKS Boost Gauge
Apexi Oil Temp, Oil Pressure, Water Temp Gauges (FAKE!!)
ATI 60mm Centre Gauge Holder
Ralliart Shift Knob
JVC Double Din Deck w/ Fold out Screen
Exterior
Varis Carbon Fibre Front Lip
Carbon Fibre Boot
Recently Purchased:
New Chinese Radiator lol
Gates Timing/Balancer Belts
Parts for Major Service (Water Pump, Bearings, Tensioners, Seals etc)
New Stock Headgasket and 1.5 WG Actuator
ARP Headstuds
GSC S2 Cams, Fidanza Cam Gears
GSC Valve Springs
Larger Turbo Outlet - 2.5"
MAP Short Runner Manifold Ceramic Coated
Muse External O2 Dump
Defi Water Temp, Oil Temp, Oil Pressure Racer Gauges
Smash 1.8 bar through this setup!!!
Wish List:
Rexpeed V Style Carbon Front Lip
Rexpeed V Style Carbon Rear Diffuser
Rexpeed Carbon Side Skirt Extension
Thanks for looking,
Lukas
Engine
K&N Pod Filter
8MR BOV
SMB 3" Front Pipe
Cusco Oil Catch Can
PTE 680cc Injectors
Walbro Fuel Pump
HKS Oil Cap
Trust Radiator Cap
Footwork & Brakes
Rays Black Lug Nuts
Interior
HKS Boost Gauge
Ralliart Shift Knob
Exterior
Carbon Fibre Boot
Recently Purchased:
ARP Headstuds
GSC Valve Springs
Wish List:
Thanks for looking,
Lukas
Update on my car:
New radiator is installed and has been working fine for the past few months.
Had the full 100,000km service done, GSC S2 cams and BC Valve Springs & Retainers and Defi Gauges installed.
Had my PowerFC retuned and I gained 42hp and 31nm of torque since the last tune. Car pulls awesome since having the cams installed.
Have some new parts that I will be installing soon:
Plazmaman UICP (Anodized red, similar to ralliart piping)
ARC Front Splitters
Synapse Synchronic Blow off Valve
I am going back to a winged look for now and removing carbon boot (more legal, less trouble from oink oink!)
Purchase an Exedy Stage 1 HD Clutch & Gruppe S lightweight flywheel
Track spec brake pads
Stickier tyres
I will then take it to the track for some fun.
Also I am trying to sort out a second hand box that is suitable for being rebuilt by sheptrans and sent over to me. If anyone knows of someone selling a second hand 5 speed transmission for a decent price please PM me. Or possibly could someone create a WTB thread for me?
I have less then 15 posts or whatever and cant make one
ARC Front Splitters
Stickier tyres
