OMORI boost gauge installed
Old Feb 17, 2004 | 06:22 AM
Mitchubishievo's Avatar
Holy moly is that a nice guage. Yet another item of interest I will have to wait to buy.
Old Feb 17, 2004 | 06:25 AM
Smogrunner's Avatar
How did you mount it on your steering column? The mount looks a little bulky, but not too bad. What is a CF pod? This is definitely the route I'm taking. That is exactly where my factory gauge was on my WRX and it was very easy to view.
Old Feb 17, 2004 | 06:36 AM
mifesto's Avatar
i can see its double-sided tape... where did you get the gauge and its mount?
Old Feb 17, 2004 | 06:43 AM
NYEVO8's Avatar
i have the same gauge and used bushner mounting cup with velcro for now. this has to be the best looking gauge i have seen and be able to adjsut the color too your prefernce without changing bulbs is the main reason i purchased it.
Old Feb 17, 2004 | 08:13 AM
rocketscience's Avatar
CF cup is the Autometer Carbon Fiber 2, 1/16 single gauge cup. I DO wish the lower mounting piece was slightly smaller/thinner. Maybe one day I'll fashion my own.. the double sided tape I got from radio shack. Outdoor, extra strong (pretty much permanent-- but can be removed). I didn't want to drill holes, but I think the top section of the steering wheel cover can't be too much anyway?. Tape's only a couple mm thick at the most. I didnt want it to vibrate or anything.. I considered velcro. And NYEVO8, I would highly suggest you try some Superlock. Also at Radio Shack or Target. They have clear and black. Superlock is much stronger and stiffer than velcro. I use it for IPASS and the turbo timer. I use velcro for the radar detector (easier to remove) and some of the loop side of velcro on the area beside and in front of the keys (car is so stiff the keys make more noise than anything else)-- this softens up the noise there. I have no problems seeing any of my other gauges. Even the 'Lancer' in the dash, along w/ seat belt warning and door open warning.
gauge from j-spectuning.com (sp?)
cup from lancershop .. i imagine others carry this as well
videos should work now, BTW
Old Feb 17, 2004 | 04:37 PM
sleet's Avatar
What size gauge did you get and what is the difference between the Mechanical and Electrical? Also where did you put the box to change the colors? Got any pictures? I'm very interested in getting one of these gauges. I almost forgot...what is that excessive beeping once you turn your car on? lol radar dector or somthing ?
Old Feb 17, 2004 | 05:55 PM
haha lol, yeah radar detector. I'm so used to it. Dont even hear it anymore. It comes on when ignition goes to on, then again when you start the car and ignition gets reset.
gauge is 52 mm which fits in the autometer 2,1/16 cup.
Here's the malaysian omori meter webpage:
http://omorimeter.com/multicolor_gauge.htm
down at the bottom is the color box.
mechanical: the only power going to gauge is the lighting, so the gauge reading itself is always on. The vacuum tube goes from engine bay to the gauge. So if you drive up a mountain and shut off the car, the gauge will read a little low. I believe they calibrate 0 at 1 atm (14.nnn psi) at sea level. Not positive tho.
Electrical: gauge is on when ignition is on. Vacuum line goes to a 'sending unit' in the engine bay which routes a wire, not a vacuum tube to the gauge. Dont have to worry about kinking the vacuum tube, wire is easier to route, but electric costs more.
As far as Omori's mechanical/electrical differences.. not sure other than above.
mounted the color box just left of the fuse box
Old Feb 18, 2004 | 07:49 AM
sleet's Avatar
You got any pictures of where you mounted the color box ? That would be my only concern trying to find a good place to mount it. I'll defenatly be getting one of these gauges
Old Apr 14, 2004 | 08:53 PM
marksae's Avatar
Where did you buy your Omori gauge from and how much was it? That gauge looks sweet!
Old Apr 15, 2004 | 07:34 AM
NYEVO8's Avatar
i mounted the color box inside the dash still accessible in 2 sec, but after setting it to match stock gauges never touched it again.
Old Apr 15, 2004 | 12:37 PM
Karash's Avatar
Looks great. Clean, simple, big up!
Old Sep 25, 2004 | 12:30 PM
MADjdm's Avatar
Ok, i know this a stupid question, but is the backlighting of the evos stock cluster amber or red??? i have scene both and now i am totaly confused??!?!
No.9
Aug 22, 2008 01:01 PM
Noize
Feb 7, 2007 10:18 AM
ernald711
Jan 12, 2007 04:26 PM
RallySport Direct
Evo 'For Sale' Exterior Styling
Jul 12, 2004 02:52 PM
NYEVO8
Feb 18, 2004 09:38 AM
