Oxidation product suggestions
Im sure im not the first or last RR evo owner to cry about his oxidized fading paint.
Wanted to know what this section would recommend to remove the oxidation. I have a Griot 6"/3" random orbital buffer with various pads.
I heard the Meguiars cleaning wax is great for swirls, tried it on a friends black bmw and worked great, but not sure about oxidation removal.
www.chemicalguys.com i have alot of there stuff. works great! the V series polish will help you out like no other. the cutting pads should help you have a bunch as well.
only worry is the paint coming off with an agressive compound, am i wrong to worry about this? at least on my 3000GT i know the paint was really soft and started to come onto the pad easily.
Maybe post a picture of the situation...I'm no expert. But I'm pretty good with it. My car was horrible oxidized and brought it back to life. Yes I did touch paint, but put a good sealant and at least monthly maintenance and should be good.
If its only sections of the car I recommend
http://www.chemicalguys.com/Chemical...ap_vkit_04.htm
Tester kit.
As for pads
http://www.chemicalguys.com/Chemical...hex_3kit_5.htm
This is what i use.
If you got a DA polisher then you'll be just fine.
Tester kit.
As for pads
This is what i use.
to me thats looking pretty bad. almost as bad as my car. I would set a full day off for this car. swirly, and oxidized pretty well.
my reccomendation:
Wash
clay
mild wash
polish
seal wax
detail spray(optional)
have you a real good advantage with a DA polisher. If you want just a touch up want to get rid of the oxdization, a mild compound with a medium foam pad will do you good. actually just maybe a polishing foam pad.
ive never used the meguiars products as stated above, but i'm sure it will get the work done. I'm just a big fan of chemical guys stuff.
my reccomendation:
Wash
clay
mild wash
polish
seal wax
My paint was just as bad if not worse. I did exactly what I just told you in earlier post and now my paint has some life in it. Shiny, smooth, and just alot better than before. Unfortunately I was compounding past the clear coat and had paint on my pad. But I think as long as you maintain proper sealnt and wax you shouldn't have any problems.
strakele
12
Mar 5, 2016 06:31 PM
LCS
Mar 28, 2011 06:48 PM
Chris@nolimitmotors
Lancer Ralliart Vendor Classifieds
Dec 21, 2007 10:02 AM
Lasersleeper
Aug 21, 2007 12:11 AM
