chipped carbon fiber wing
It looks like a small rock hit the edge of my spoiler(C.F. portion). Does anyone have any suggestions to fix? Do I take it to a body shop or do I have to replace it. It's the long middle shaft, about the size of a quarter, fairly superficial.
If you intend to keep the wing you need to get some clear epoxy and seal the damaged area from the atmosphere ASAP. You may also want to put some clear mylar tape over the damage area. This will prevent moisture from entering the area and causing delamination. Composites can be repaired, but it won’t look as uniform as it did coming from the factory. I can’t imagine your typical body shop would be the place to go for something like that. You would have to find a company that specializes in graphite materials. I would highly recommend someone who has knowledge of aircraft composite repairs. I’m not sure how a proper composite repair would compare price wise with just getting a new airfoil.
Best wishes,
f86sabre
Best wishes,
f86sabre
I have a feeling the cost of a new CF wing from the dealer will be sky-high (hopefully insurance will cover it). I would see if anyone is selling theirs in the classifieds and just re-paint it.
__________________
"Let us help you build your JDM dream!"
www.bulletproofautomotive.com
The Real JDM - Interactive (blog)
Email: sales@bulletproofautomotive.com
Direct North American Dealers for Voltex, Mines, Varis, First Molding, HKS Kansai, Cusco, HKS, Advan, Volk, Ings+1, C-West, Work, and so much more...
sorry to hear that but clear epoxy should help or some product named goop, I do not know if it will be the same though. some professional shops dealing with cf should be able to help without replacing the whole wing
Originally posted by Lubinsky
How much would that piece cost?
What a rip! My dad has been fixing surfboard dings for 35 yr.'s, so I'm going to hook up with him. He's a pro. Thanks for the info. All he needed to know is if it's fiberglass or epoxy, apparently epoxy.
If your dad has composite experience then you should be ok. In your last post you said you wanted to know if the wing was fiberglass or epoxy. The wings are carbon fiber reinforced plastic, not fiberglass. Fiberglass is a good bit easier to work with than carbon fiber. I’m not sure what kind of resin system is used with this wing.
Good luck and best wishes,
f86sabre
f86sabre
hey dont worry about chippin CF wing.. I took Automotive collison Techician. use Fiberglass if it big chip.. small hole do sand And Repaint the clearcoat on Cf wing.. im not right yet.. same thing on my friend Honda front lip big chip so i fixed it and repaint only clearcoat that all
flyinmonkey101
30
Dec 27, 2016 08:46 PM
B Pars
Aug 23, 2004 08:58 PM
