New Gauges Installed
Old Apr 15, 2004 | 06:11 PM
eclipsegs2k1's Avatar
they work now, thanks, looking good... how do you like that a/f guage?
Old Apr 15, 2004 | 10:14 PM
EVOKing8's Avatar
i like it looks cool at night cause all u see is the LED goin back and forth
Old Apr 16, 2004 | 10:13 AM
sillypuddy's Avatar
i would have went with oil temp, boost and egt
I find that the a/f with the stock o2 doesn't really tell you anything... just bling bling
-joe
Old Apr 16, 2004 | 10:21 AM
93civEJ1's Avatar
looks really good man...i have the same gauges "Phantom" and like them, but i didnt opt for the pillar pod setup...I did the DIY pod
Old Apr 20, 2004 | 02:22 PM
Mr_Ginzo's Avatar
i like, how do air-fuel gauges read?
Old Apr 20, 2004 | 07:44 PM
Shahul X's Avatar
the AF guage isnt a wideband obviously, you can get em for $80 or less (try lancershop).....
but the AF guage is better than nothing........ I wonder how this works with the UTEC or EMS
-shahul
Old Apr 22, 2004 | 02:55 PM
bolsen's Avatar
Yea the A/F gauge works good for making a blinking light move around.
I would have got oil pressure / temp / egt / boost.
Old Apr 22, 2004 | 09:13 PM
Jadiem's Avatar
only thing i don't like is that it doesn't match the other A pillar
Old Apr 22, 2004 | 09:41 PM
viciousv322's Avatar
Originally posted by EVOKing8
Why would i need to switch files?
The SAFC can hold two files which you can switch on the fly...
The reason you MIGHT want to switch files might be if you wanted to run a little leaner or if you were raising your boost and wanted to compensate w/ fuel.
OR
The extra map could be used if you run race gas or use tolulene (or some other type of octane booster)
but i guess you're right... you probably wouldn't use it very often...
