BR 20G-9 Pics
Just thought I'd share as it will be sitting around for a little while...
http://www.justchil.net/albums/evo_2...2058.sized.jpg http://www.justchil.net/albums/evo_2...2061.sized.jpg http://www.justchil.net/albums/evo_2...2063.sized.jpg http://www.justchil.net/albums/evo_2...2066.sized.jpg 20g-9 with lower piping and coolant / oil feed line http://www.justchil.net/albums/evo_2...2086.sized.jpg http://www.justchil.net/albums/evo_2...2089.sized.jpg Almost ready for installation: http://www.justchil.net/albums/evo_2...2121.sized.jpg http://www.justchil.net/albums/evo_2...2123.sized.jpg http://www.justchil.net/albums/evo_2...2125.sized.jpg http://www.justchil.net/albums/evo_2...2126.sized.jpg :thumbup: :thumbup: :thumbup: |
how much are those 20g-9's from BR?
I believe they are 1350. Give them a call or check out their website for a more solid answer: http://www.buschurracing.com
:yum: man i can't wait.....
Edit* Did you get yours with the ti/al? when are you installing? |
Droooool. :drool:
No ti/al wheel. I'll be installing as soon as the install kits get in.. also be adding a ported/coated mani & o2. Probably some other goodies.
Should be on the dyno @ BR late January (depending how long the install kits take) |
that is nice...
Wow that looks like fun...
I called them and they quoted me $1500, and $1750 with an actuator. My question is what does the actuator do, and is it worth the money?
ahhhhhhhhhh
get it or the upgrade that is. it helps hold boost to redline with little or no taper
Are these turbo's realy that much better than a 10.5 upgrade, because they are really expensive? I can't find any literature that says exactly what upgrades are done to the IX turbo to make the 20g-9. I would like to know what exactly the $1750 will get me.
There are several threads on this turbo.. check them out :)
I'm running the 03 9.8 hotside so this should be a pretty nice improvement. I'll have detailed installation instructions and some nice dyno comparisons up after it's all done. |
Lets see the results, This might be my first mod of 2006, with alky kit and tune.
Nice purchase! Ive gotta see it when its all done! That should get you into the mid 300's on that mustang dyno fo sure...
WV evos rule! :lol: |
