Brembo, clear coat wax?
So I have done some research, and obviously I know that the brembo's peel, so I was just wondering, I have a IX, and I know supposedly the paint is supposed to be better on these brembo's, but in order to prevent the peeling from happening in the future is it possible to put say a clear coat finish on them, like you would after waxing, to prevent this?? I know this could be a potentially dumb question, but I was just curious...I mean I know the high heat would probably play an effect on it....if not that...is there any clear coat spray, etc. I could use to prevent the peeling from ever happening?
You could use a sealant wax. I clean and seal my calipers everytime I switch my tires
Err wax can't handle the heat.
how often do u truely heat up them up huh? clearcoat on the brembos dont go because of heat... they BROWN. this is a big misconception. clearcoat on the brembos peel and turn white because people dont take care of um.
keep the brake dust off religiously and wax often and u WILL be fine i hate talking about this w/ people because many are so thick headed..... clearcoat on brembos and CF spoilers are PAINT! u cant leave paint exposted without wax while leaving dirt and brake dust to eat away at it over time and still expect it to look good. brake calipers get POUNDED by dirt and brake dust, the paint on the brembos need to be religously protected. |
I just learned the hard way never use a wheel cleaner like Meguires hot rims stuff took a nice big chunk of clear off my front passenger caliper use soap and water too answer your question should work i dont see why not.
Ok, this is what I was thinking, should work. Normally, I never use products besides brake dust remover on my rims. When I spray my tires I have a cut out that I put over the rims to not get ANY spray on the rims, rotors, calipers, etc. Think I'll just stick with cleaning them once a week, when I normally wash the car, and put some sealant clear coat over it once a month. That should keep it clear. Thanks for all the input!
I use nothing but soap and water on my wheels and calipers and they still peel. I cleaner them once a week. I never use solvents or cleaners. I have had the dealer replace my front's beforew they put a ban on doing so and now my second set is peeling. It must be the way Brembo put's the clear on.
wax also?
1 Attachment(s)
Yup, don't use harsh solvents. Just water and soap and it should be fine. Mine has been through some abuse with wheel cleaners and harsh chemicals so the peel has started. I had to repaint mine.
Originally Posted by mifesto
(Post 4200775)
Waxing your calipers. I guess this must be the official car for the metro sexual.
Originally Posted by grillpt
(Post 4200823)
Originally Posted by Kordwood
(Post 4201238)
Waxing will just clean them and not protect them. If want that constant shine, just use a rubbing compound on them very carefully and then use a high temperature clear coat. After I repainted my Bremos, I used a high temperature or engine enamel clear coat and it always stay shinny, not like before the peeling.
to evo732man-------------wax cleans but doesnt protect? u got it in reverse buddy. besides cleaner wax which i personally never recommend to anyone, wax doesnt clean but only protects. ur wheel wouldnt have peeled probably if u actually waxed ur wheels. u do know most wheels have clearcoat too right? guess u didnt.
as for u spraying any paint, i would NEVER recommend that to anyone unless their calipers are already peeling and mitsu denied them. if u paint ur own, wave goodbye w/ anyone chance mitsu will replace. to answer MYDREAMEVO, waxing the calipers makes perfect sense considering they are PAINTED SURFACE. |
