some before & after pic's EB Evo IX
before
http://i150.photobucket.com/albums/s...03_565x421.jpg After http://i150.photobucket.com/albums/s...O/DSC00162.jpg Before http://i150.photobucket.com/albums/s...06_565x421.jpg After http://i150.photobucket.com/albums/s...O/DSC00163.jpg Before http://i150.photobucket.com/albums/s...09_565x421.jpg After http://i150.photobucket.com/albums/s...O/DSC00166.jpg http://i150.photobucket.com/albums/s...O/DSC00165.jpg http://i150.photobucket.com/albums/s...O/DSC00164.jpg And here's 2 pic's of inside http://i150.photobucket.com/albums/s...O/DSC00169.jpg http://i150.photobucket.com/albums/s...O/DSC00156.jpg Still a work in progress |
A drop and some wheels is a must...
not bad... i definately gotta snap some pix of my EB IX
Yeah i know i need rims :lol: just trying to figure the offset. looking to buy volk ce28n 18x9.5 with a 28+ offset front and 34+ offset rear. on the volk site it says 28+ will clear the front but the 34+ in the rear does not. it just says it will clear for the evo X. but i read on this fourm that this set up works and clears rears, and that i would not have to roll the fenders. if anyone has any info about the offset and if this set up would work PLEASE chime in i would like to order the rims this week.
I really like how the new look likes especially the lip. gjob
Where did you get the coolant overflow tank from?
Originally Posted by tazz5425
(Post 8333304)
If you are gonna drop the car, lets say on Swift Spec R Springs(which have a mild drop), than you are better off going with a +28 all around. The reason being is that you will still need a spacer if you plan to use a 265/35 tire with the +34. The spacer is not needed for caliper clearance but for strut perch clearance. So in the end you end up with a lower effective offset if you run a the +34 with a 5 mm spacer which will put you at +29. So just do the +28. There are several people running 18x9.5 RE30s and CE28ns in the +28 with no fender mods... AS LONG AS THE CAR IS NOT SLAMMED. If you end up with Coilovers than you will have alot more room to play with. As for a tire, you can minimize the chance of rubbing even less by running a 255/35 instead so you need to decide what tire to use. Use the search button, there are a bunch of people running this size and offset. Its a considered a pretty "conservative" semi aggressive offset for an 18x9.5 so you shouldn't have to many issues if any with rubbing without rolling the fenders. |
well for now i was going to keep the stock suspension and see how she looked. the tire size i was going to get where the 225/35. but if i was going to get new shocks i would go with coilovers.
love everything (even the eyelids) besides the rain guards on the windows.
Originally Posted by ch53avitech
(Post 8333431)
(Post 8333711)
If you are gonna run these wheels on a stock suspension no mods needed. You can fit 20 inch wheels under our stock 4x4 truck clearance:lol: |
:lol: yeah 255/35 my bad. with coilovers
Interesting upgrade path. Car looks good though.
Originally Posted by Remixx02
(Post 8333044)
Looks like you have put a bit of work into it, looks nice! Keep up the good work.
| All times are GMT -7. The time now is 02:03 PM. |
