-   Evo Show / Shine (https://www.evolutionm.net/forums/evo-show-shine-86/)
-   -   Gilbert's 695WHP /526 Torque -FP Black E-85 - (https://www.evolutionm.net/forums/evo-show-shine/626490-gilberts-695whp-526-torque-fp-black-e-85-a.html)
Jedi_Gill Aug 28, 2012 11:08 AM
Hello Everyone,
Just wanted to give you an update on my car.. (Nicknamed "EVA")
I recently made a few cosmetic changes and a few small performance upgrades.. The car is now making making 695whp/526 Torque on the Dyno.
https://dl.dropbox.com/u/5055273/Evo...e%20Medium.JPG
https://dl.dropbox.com/u/5055273/Dyn...et%20Front.jpg
https://dl.dropbox.com/u/5055273/Dyn...eet%20Back.jpg
Also I know it's hard to tell in these pictures but I painted the car from it's original Arctic Silver to a Quartz Gray. Plus some CCW's, Carbon Sideskirts.
https://dl.dropbox.com/u/5055273/Dyn...ght%20Rear.jpg
https://dl.dropbox.com/u/5055273/Dyn...ht%20Close.jpg
https://dl.dropbox.com/u/5055273/Dyn...Evo%20Rear.jpg
https://dl.dropbox.com/u/5055273/Dyn...ear%20Side.jpg
https://dl.dropbox.com/u/5055273/Dyn...ar%20Seats.jpg
https://dl.dropbox.com/u/5055273/Dyn...ver%20Side.jpg
https://dl.dropbox.com/u/5055273/Dyn...sh%20Group.jpg
https://dl.dropbox.com/u/5055273/For...FP%20Black.jpg
You would Never Guess it.. but The Car on the right is actually faster :) ha ha..
https://dl.dropbox.com/u/5055273/Dyn...vo%20Lambo.jpg
I would like to thank my closest friends and shops that made all of this possible..
Steve Roque, Justin Rush, Andrew@AMS, Rich Molina, Robert Lebron, Strictly Modified, AMS, Adam(Devo Tunning), MAPerformance, Buschur Racing, Rush Group Detailing, and most important of all, my wife Grace Garcia for her support of this expensive hobby of mine :)
BTW.. I just had a new baby boy Phoenix Alexander Garcia.. I'm sure he's going to learn from Daddy and get in the car scene as well.
https://dl.dropbox.com/u/5055273/Dyn...0Alexander.jpg
Jedi_Gill Aug 28, 2012 11:10 AM
Sweet.. I am honored to be asked to be in the Spark Tech Showcase..
http://www.sparktechignitions.net/v2hmain-gallery.html
Advertising aside, these coils really did greatly help all the misfires issues I was having.. I highly recommend them.
Jedi_Gill Aug 28, 2012 11:19 AM
Thanks again for reading. Below is a list of all my mods: I may have forgotten some :)
Engine Power Mods:
Fully Built Bottom End 2.0 Liter from Class One motors with a 9.5 to 1 Piston Compression
9.5 JE Custom Pistons
Oliver I Beam Rods
Kelford Cams 272 intake and Exhaust
Fidanza Cam Gears with Clear Cam Cover
Kiggly Springs and Retainers
Kiggly Upgraded Oil Pressure Head Regulator
Forced Performance Black Turbo
MAP Custom Catch Can with functional Crank Case Release modification to the Head.
High Pressure Wastegate Actuator for 30PSI Boost
Tial QR Black Recurculating Blow Off Valve Welded to Upper Intercooler Pipe
AMS Black Fuel Rail
Buschur Double Pumper
Injector Dynamic 2000cc Injectors
Spark Tech - Plug and Play Ignition Coils
Boost Solenoid Boost Controller
K&N Air Intake
Buschur J Pipe
AMS New End Tank Front Mount Intercooler
Larger O2 Housing with Loko Thermal Coating
AMS Mini Battery Kit
AMS Upper Intercooler Pipe
AMS Lower Intercooler Pipe
Samco Hoses to entire Air system
AMS 3” Downpipe
AMS 3” Test Pipe (Cat Delete) With resonator
AMS 3” Vibrant Full Exhaust with Modified JDM Exhaust
MAPerformance Level 2 Heavily Ported and Heat Soak Black Paint Coated Intake Manifold
Hondata Heat Shield and Vellum Intake manifold Gasket
Boomba 75mm Throttle Body
Loko Thermal Coating on Turbo
Ported Exhaust Manifold and Loko Thermal Coating
Quartermaster Twin Disk Clutch with lightweight Flywheel
Devo 2 Piece Light Weight Drive Shaft
E-85 Speed Density ECU tunning by AMS
Interior Mods:
Full Leather package upgrade including door panels. (Originally had suede interior)
Trustz Black Evo 8 Gauge Overlays
Evo 9 Black Steering wheel swapped to match interior better
AEM 50 psi Boost Gauge
AEM Uego multiface Air Fuel Ratio Wideband Gauge
AEM Oil Pressure Gauge
Custom In-Gauge Oil Pressure modification by Rush Group Detailing Boltz
Dash Pieces where painted to Satin Black
Shifter Cover was painted to Satin Black
Heating Controls where relocated to a custom molded Cubby Hole then painted to Satin Black
Car Computer Installed (2Ghz, 1GB Ram, 30GB SSD Drive) integrated under my car seat.
7” Xenarc Computer Touch screen
Computer Screen Custom Mold to dash then painted satin Black.
Metal Shifter Bushings installed for better feel of my Stick Gear selector
GPS integrated in the Driver’s side pillar for the Co-Pilot GPS Software
Wireless Network Card integrated inside the Pillar for Wireless Connectivity
200 Watt 4 Channel Amplifier Installed in Glove Box for Car computer sound
Autopage C3 2 way 1 Mile transmitter range alarm installed.
Autopage GPS module with 24/7 Satellite Tracking Antitheft device installed with phone GUI.
Exterior Mods:
Evo 8 Front Bumper Custom made to look like the Evo 9 bumper with shaved Mitsubishi logo
Blacked out Front Headlights with Yellow tinted markers removed to clear glass color
Blacked out Rear Taillights with Yellow tinted markers removed to clear glass color
JDM Rear Bumper installed
Afterhours Custom Made lightweight crash beam with anti-rust coating for the JDM Rear bumper
Smoked color side turn Signals
Mitsibishi Original Vortex Generated Custom painted to Glossy Black.
Mini Short Antenna
Carbon Fiber Varis Front lip installed
Carbon Fiber RexSpeed SideSkirts
Centric Performance Slotted and Lightweight Front Rotors
Centric Performance Slotted and Lightweight Rear Rotors
Peformance Friction Front Brakes
Peformance Friction Rear Brakes
DriveTrain/Suspension/Wheels:
Jacks Transmissions Built Trans
Wave Track LSD in Center Differential
TRE Built Rear Differential
Rear Metal Bushing to help with Launching
Stance Full Coilover suspension
CCW Wheels
Performance Racing Tires
Brembo Calipers in front and rear painted to Semi-Gloss Black
Brembo Sticker re-applied to painted calipers with custom design in the rear brake calipers
Mistaken Aug 28, 2012 11:24 AM
VERY nice numbers.
Jedi_Gill Aug 28, 2012 11:34 AM
Originally Posted by Mistaken (Post 10367949)
VERY nice numbers.
Thanks, I'm the first owner and it's been 8 years in the making.. I'm very proud of my Eva.. She is in essence the result of a culmination of all those Studying hours at college and hours of work saving up for her.
This didn't come cheap nor easy but it's always been a dream of mine to have a nice looking 10 second car and I'm glad I've now achieved that dream now.
Surprisingly buying this car also brought me my closest friendships and my wife.. which I guess I could say my son as well. Cheers. :beer:
PatricksEvilEvo Aug 28, 2012 12:25 PM
Looks awesome man! Great numbers too! That lambo is ridiculous.
SS2EVO Aug 28, 2012 12:31 PM
Awesome looking car and very nice numbers!
sujinX Aug 28, 2012 02:01 PM
PERFECT! love the wheels and stance (not to be confused with stance/) of the car.
i dont even wanna ask how much u spent.
very well done sir
Jedi_Gill Aug 28, 2012 04:00 PM
very well done sir
You can't think of this.. as money at one time. This was an accumulation of money year after year.. If you add up what you or the everyday person spends on their car you'd be surprised at how much it really is.. I just spend a bit more outside that yearly cost in 8 years to build this dream car..
How much would you say your dream is worth.. to me.. < 60K isn't that bad.
Keep in mind a lot of my money didn't just go to mods, there are plenty of other mods that you might not see or immediately notice that cost quite a bit.. The paint Job for example wasn't cheap but to me was the final touch on my masterpiece.
These pictures don't capture the color correctly and I need better light to really show the Quartz Gray color but I plan on a photo-shoot soon so you'll see it better then.
Chef-j Aug 28, 2012 04:02 PM
One of best looking evo!
Evoryder Aug 28, 2012 04:05 PM
Very nicely done, and well said. Car is tastefully modded. Congrats on the son!
RazorLab Aug 28, 2012 04:10 PM
Great looking Evo!
Jedi_Gill Aug 28, 2012 04:12 PM
Thank you on the compliments of the car.. and thank you on the birth of my son..
My son is now my new project masterpiece I plan to work on for the next few years.. :) Enjoying fatherhood so far.. :thumbup:
Jedi_Gill Aug 28, 2012 04:13 PM
VERY nice numbers.
You know I'm curious.. I don't know if this is a record or something.. but for a 2.0 motor on E-85 with a FP Black, I think it's definitely up there.
importmachine Aug 29, 2012 01:19 AM
Your car looks so well put together and smart. Fantastic job my friend. I've found an inspiration for my evo now. {thumbup}
