-   Evo Show / Shine (https://www.evolutionm.net/forums/evo-show-shine-86/)
-   -   cutoff using HID's in evo 9 gsr non HID housings? (https://www.evolutionm.net/forums/evo-show-shine/652829-cutoff-using-hids-evo-9-gsr-non-hid-housings.html)
woolleyfooley Apr 3, 2013 06:05 PM
Hey evom, im just wondering what the cutoff pattern of the low beams would be if i used HID's in the oem evo 9 gsr non HID housings. Anyone have any experience with this? Just dont want to ruin the nice cutoff by putting an HID kit in. Oh and yes i have searched and couldnt find a definite answer to this. Thanks everyone
llDemonll Apr 3, 2013 06:48 PM
ideally it would be the same as the halogens. might not be as sharp as the hid projectors but it should be plenty sharp to not piss off other drivers and have a proper cutoff
Ichiban Apr 3, 2013 07:14 PM
Reflector inside projector is different so cutoff won't be as sharp. Light will also leak up above the cutoff and glare. Not recommended but everyone has their own idea of tolerable. It's also harder to get a good color match or proper intensity with rebased bulbs. Your visibility might even be diminished based on what Kelvin your bulbs end up being. Take a look on the forums at www.hidplanet.com. Lots of good information regarding this topic there.
Ideally you'll want to get the proper housings or retrofit your existing housings with proper HID projectors. TRS (www.theretrofitsource.com) is a good vendor to purchase these from. I've purchased retro parts from them many times without issue.
90zcrex Apr 3, 2013 07:28 PM
Someone installed HID's in my gsr before i bought it. When i found out i had non hid projectors I switched back to halogen. Didn't notice any difference in light output and the cutoff line looked the same as before so I don't think its a problem at all.
FameEvo Apr 6, 2013 10:33 PM
Buy set of mr headlight set or GSR projector ones ill show you how to wire them up using your oem harness I did it to my 04 Rs I have factory projecters with fogs :)
