What are the EVO's F+R speaker sizes and depth?
Well what is the maximum diameter and depth is the front and rear speakers on the EVO?
The front speakers are 6.5 inches and a max depth of about 2.75 inches before it will hit the window when it comes down. The rear is the same size but unlimited depth because it is in the trunk!
pls delete
Originally Posted by outsider
no EVO comes with those tires... considering each tire costs about $250 I would demand the real OEM tires or $1000 to go buy them
What the hell are you talking about? This is speakers not tires. |
I posted in the wrong thread |
what speakers are u looking at putting in yours? I have infinity kappa perfects there like mini subs and they fit no problem well i did have to retrofit me a bracket but hey thats my job
heh i just bought a set of the kenwoods... ill make em fit!
I wanna hear how those Kenwoods sound compared to Kappa Perfects, Kicker SS, and MTX Thunder Axe components.
I have some Alpine Type R Components sitting around from my old car that I never got around to installing, how will they fit?
btw msrp on those speakers is 999 and ya can get em on ebay for ~450 shipped. the guy i got mine from packed those things soooo well. it was boxes within boxes within peanuts, within another box, and then the retail packaging, i was very impressed to say the least.
All speaker openings are 6.75 inches. If you use a typical 6 1/2" speaker , you will need to cut an adapter out of MDF or something similar. For the front you will need 1/4" or 1/2" thickness to gain clearance from the window when lowered.
Originally Posted by wj4
im a noob to the the evo and in the process of upgrading the system as well. can u plz explain more about making the 6.5 speakers fit in the opening? :)
6 1/2s fit. Crutchfield sells install kits to make 6 1/2s work in a lancer/evo. It comes with the adaptor plates and plug and play harnesses the plug right in to the factory speaker harness. You get the install kit for free if you order the speakers from crutchfield. |
| All times are GMT -7. The time now is 01:42 AM. |
