Steering wheel shakes during high speed braking
#32
did the problem start before or after you got those pads? I highly doubt you've warped them because i have done 10+ track events with the stock rotors and with competition race pads and they are straight. It seemes like every time i switched from my track pads to the stock pads, my car would convulse under light pedal pressure, so i have been just driving around the streets with racing pads.
#33
I had that happen after a few thousand miles on my car.
I bedded the pads in at the track and never had any problems after that.
Here's a post by Chronohunter (professional driver) regarding the topic:
Yep, it's a "material transfer" problem. You can clean them (or cook them clean) by heating them up to the point of light fade and then slow the car to a stop using no brakes if possible, you must coast the last foot with out ANY brake then kill the car in gear (no hand brake) and let it cool all the way down (1/2 hour or so). Now drive away and your "warped" rotors have magicly straightened . You can repeat this as many times a necessary over the life of the pads. Next time get some Ferodos/ Hawks/Pagids which don't have transfer issues
Originally Posted by lithe
After reading a good FAQ article on Stoptech's website I think I can assume that my "warped rotor" problem that has only begun recently is actually just pad deposite from the "soft" stock brake pads.
The advised to have the rotors cleaned-different than resurfacing, and switching to a harder, semi-metallic pad. I assume the Ferrodo DS2500's would fit the bill? Anyone know the best place to buy these?
Sorry to take this thread slightly off topic...I think I brought it back nicely though Can anyone confirm that my assessment/solution/line of reasoning is correct?
I haven't tracked my car or let the hot pads sit on the rotor after a long or aggressive stop...so I really think it's just deposits. Any input or similar experiences/solutions would be great! Thanks!
#34
Originally Posted by wiretap
Told you guys.. they use an impact gun to tighten the lugs.. it shocks the rotor when they torque them on, causing it to warp in one direction.. it only does it by a few thousands of an inch though, which makes a big difference. I notice it every time someone tightens my lugs with a impact gun too. Use a torque wrench to do it properly. (star pattern, tighten 50%, then go back and finish them off 100%) I guess the specs for an evo are 72 ft/lb.. I was looking at a chart on discount tire's website, sorry for the mistake. It was correct for my car, so I thought they would have got the evo's specs right, guess not.
If you have never heard in all your years of racing that it does this, I'm sorry.. It was also featured on a racing special on speedvision where they talk with pit crews. The "race cars" don't warp as easily because they have brake rotors designed so they don't warp easy, also most of them are using only 1 lug if it is a real race car..
#35
I'm talking about when they just have their impact guns set too high, which nearly every tire shop does.. you think they actually take the time to set it to each persons car specs? The last 2 times someone used an impact gun on my car, they had it set to around 120-140 ft/lb and I could barely get my lugnuts off.. it warped my rotors.. It isn't mis-information.. the shock from suddenly tightening the lugs, especially at high torque settings WILL warp a rotor.
#36
Proper bedding, warmup and cooldown are what you should be trying to accomplish and even then if you get your brakes good and hot you can still get pulsing from uneven deposits. Fixing it - which can be repeated as often as necessary should generally follow the following steps:
Rebed aggressively once or twice and see if it at least diminishes - (heading in the right direction) - Pay particular attention to cooldown.....thats where the problems tend to start.
Nailing your brakes when they are cold w/ even mildly aggressive pads can also 'strip' a perfectly good transfer layer and lead to judder. And be careful not to overheat the rotors or pads - that can lead to other problems. That's why a race team will use temperature paint - so they can be precise.
Try some garnett paper and lots of elbow grease - then rebed.
As a last resort turn the rotors - it's a waste of good heat sink but at this point you are trying to salvage something of your rotors before replacing them.
If you consistently have this problem then I would say you have the wrong pads for the way you drive or you simply are not listening!! Brakes are as complicated as anything on your car and as a safety item require due diligence. Consider this:
Your brakes are probably the only system on your car that can only take about 10 or so full effort events before performance begins to suffer pretty badly. Your engine can likely run 13 sec quarters all day - 10 repeated stops from 120 will likely have your brakes begging for mercy.
#37
http://www.raceshopper.com/how_to_install_brakes.shtml
http://www.autoeducation.com/autoshop101/brakes.htm
http://www.advanceautoparts.com/engl...0050201rr.html
http://www.domain-b.com/automotive/g...8aug/brake.htm
Theres just some supporting evidence to how impact guns can warp rotors..
I'm not saying this is causing YOUR problem, its just something to be careful of.
#38
Anj, how did it go with rebedding the pads? As you know ive got the same issue, it happens when the brakes are warm and at slight pedal pressure. Drive for about 15 minutes on the hwy without using them and they are ok, but heat them up again and its back to the shimmy.
#39
I did the rebedding process twice this weekend...mainly because it was tough finding a spot to do 10 consecutive 60-0 stops without attracting the local law enforcement's attention, but also because I figured it couldn't hurt to do it once more for good measure.
I did about 8 60-0 stops, drove around for 2-3 miles and then parked the car in my driveway. I waited about 2 hours, and then did probably 10 or 11 60-0 stops and then drove for 5 miles using the brakes ever so lightly once or twice, and then parked it again.
Didn't drive the car the entire weekend, and this morning on the way to work, the steering wheel still shook at 80+ mph braking
This is so gay.
This is so gay.
#41
Did you recently rotate or remove the wheels? Had the same problem (at high speeds) after I had new wheels put on. The guy who installed the wheels torqued the #$%@ outta the lug nuts, I loosened the lugs and re-torqued em to a lower lb. and then did the heat up the rotor trick. Problem solved. Be sure to check em for tightness after a day or so, to ensure they have seated on the hub correctly.
#43
This is so gay.
This is so gay.
What ever you do, DONT go to th dealer b/c they will just resurface the rotors.......order a set of ferodo DS2500's.......these pads are harder than stock and will prevent the pad material transfer phenomenon from occuring. I had the same exact problem! I noticed that it got worse during summer months. Do a search under 75,000 mile review and read #2.
Bobby
#44
What could this be caused by? I don't think I have warped rotors as the shaking goes away if I brake hard at lower speeds. I've also noticed that the shaking happens at light pedal pressure; if I increase pedal pressure, the shaking goes away somewhat.
Could it be wheel weights? I only have 8500 miles on my car, FWIW.
#45
Ok, I read this whole thread. I just installed Ferrado DS 2500 front and back, did a flush, put Motul 600 fluid in. Bed the brakes per the directions supplied with said brakes. Went to an Autox on Sunday and on the way ther I noticed wheel shake when brakeing lightly at speed. If I slam on the brakes all is good. I rotated the tires also. Car was aligned within the past 3 months.
So I know that I should re-bed the brakes. Only other option is to replace all the rotors I guess. I hope I can use these pads with new rotors, I am sure that is the case. When doing rotors, I assume everyone does front and back. It would be a hell of alot easier just to do the front, on my wallet that is.
