Possibly the best street springs out there?
Just received a set of the new Swift Spec R springs, after testing their race springs on a SPA shock dyno all I can say is if their street springs are as good as their race springs this may be the best street spring on the market. I am making dyno adaptors to run the street springs and will have info soon. Running them with stock struts first, then Bilstein struts for a back to back on the road test. Just my 2 cents
Spec R*****
RS/GSR - Front Spring Rates: 3.2 - 4.8 kg/mm (179 - 269 lbs/inch), Rear Spring Rates: 3.7 - 5.7 kg/mm (207 - 319 lbs/inch)
RS/GSR Ride Height Drop: 1.4" Front and 0.8" Rear
vs
MACH*****
Drop Rate (F/R): 1.38/0.79"
Spring Rate (F/R): 2.5-4.0/3.1-6.6kg
Slightly more aggressive, and more stiff im trying to find the spring rates right now.
This is all i could find it might/might not be 100% correct but i think the rates are actually the same just the spec R is a more aggressive spring.
vs
MACH*****
We tested the rates on the regular Swifts a long time ago when we made our own GTWorx springs and had some interesting results.
- Andrew
The testing is being done because I will not put a spring or any other product on my vehicle unless I know for a fact it will perform as expected . Being in race car component development for 25 years I have seen many springs coil bind, sag, and drop rate. The main thing is I think this spring company has found some things other companies have possibly missed, and after testing their race springs I have found very positive results. Enough so one of the top IRL indy car technical directors I brought this up with thought so also. By the way he is a multi Indy 500 and Championship winning engineer. Also having a street car I have not seen the need for coilovers as the Bilstein strut do the job for most street applications if the unsprung mass is not increased ie. staying with a wheel as light or lighter than BBS MR wheels at 17" diameter. Anything heavier ie. 18" wheels and tires with stock struts will degrade the ride and control of the vehicle. This is just one persons opinion but it would be interesting to take some other manufactures products for a spin on our 7 post rig to really see what is happening.
FYI I found a source for Bilstein struts at www.allshocks.com. I will be checking to see if there are any differences between their MR vs HD strut on our shock dyno. BTW great prices!
I'm not here to start anything, but just some info for the masses who want to get what they pay for. BTW how many parts shops have the proper testing facilities to back up thier claims ie. shock dyno, 7 post rig, and some of the best race engineers around that do development for all the major race series. I'm just a guy that happens to care about what I put into my car and not one that just takes others words untill I see the results for myself. I conceive, design, build and test racing components how many parts shops do that. The only one I know is Buschers, at least Dave can be respected for that because he actually does the development and is willing to call it as he sees it.
I agree on not seeing the need for coilovers for a street EVO. I've been preaching that for a while but many people here love to jump right into cheap, poorly made coilovers with improper and wildly inconsistent valving.
I've recently sent out a couple sets of the Bilstein HD dampers with either our GTWorx springs our the standard Swift sport springs and the reviews should be popping up soon. IMO it's a better solution for most EVO drivers that see 90% or more street driving and are not running 275 r-comp tires.
We did test the standard Swifts a while ago, I'll PM you details.
sending you a PM
- Andrew
We're a small shop, but we don't let it stop us from putting out great, effective parts with real research and development behind them.
- drew
