Front Ball Joint Replacement - Warning
#50
Hate to bump an almost year old thread but
Moog does NOT have a new part number -- I called them and they had no idea the evo was different from the base lancer...
Wow - - wtf.
As of today -- Advance, Checkers, Autozone, Napa and posisblly carquest all have that wrong parts instock. Made by different companies - Moog, Federal, Duralast, etc.
Wow - - wtf.
#52
boot
Is the boot replaceable??? im sure it isnt hard. Is there a specific tool used?? or is it one of those things where you just put it on and put the rest of the parts back on and it will install itself??
#53
I have a low mileage car and my ball joint but the boot is torn.
Can you get a new rubber boot for the ball joint from the dealer?
Does anyone know how to remove the old boot and put the new one on?
#55
Hey guys, Im lookin for a write up on this install. There is no shops around here I would trust other than myself. I have an evo 9 rs, and need new ball joints. Well.. actually 1, but Im on swift springs so id like to correct some of the bad ju ju lowering while Im at it.
The thing that gets me is you say they are not symmetrical. is that based on an axial view or radius type view. Thank you for the time. Please post some responses!
#56
So can you use the White line kit on a car that isn't slammed? My car is lowered on Eibach springs, unsure if they are Prokit or Sportlines. My front drivers side lower control arm is bent from the previous owner, I got a used one but the ball joint is trashed so I pressed it out. The ball joint on the bent arm is good, but I don't think I can press it out without damaging it.
#58
Worse comes to worse - your not any worse off if you try.
Remove retaining clip, and grind/cut(optional) off the crimp and press slowly.
#59
Yes call the dealer I purchased two boots for about $15 each. You can buy just the boot. And to answer someone elses question I just used a socket to tap the boot on it has a steel ring around the base.
