Enkei RPF1 17x9.5 on Evo (confirm this plz)
#61
just found this thread via search. any updates? i'd like to run a 275 tire on my 17x9.5 +38 RPFs. i currently get a bit of rear, lower control arm rub from the wheels.. i imagine the tire will rub for sure. i have my rear fenders rolled but not pulled. fronts have enough fender gap that i'm not worried. running KW coilovers and 20mm spacers up front, so guessing i have plenty of room there.
Make sure your tire shop didn't put clip-on weights on the inside of your wheels, though. I had a tire shop put a single clip-on weight on the inside of my 17x9.5 +38 RPF-1s, and that was enough to just barely catch the control arm under hard cornering. But once I pried that weight off I had plenty of clearance on the wheels at least.
#62
You're getting lower control arm rub from the wheels? You should have enough clearance there.
#63
Although if your bushings were completely spent then that might also explain it. I'd suggest getting those replaced.
#64
I didn't think I had any clip-on weights either, because I specifically asked the shop to only use sticky weights and I saw a bunch of sticky weights inside the wheel. But when I climbed under the car, I found that they had also used some clip-on weights to balance the wheels.
guyver858
Mar 13, 2012 06:16 AM
hamflex
For Sale - Wheels / Tires
Jul 18, 2011 08:15 AM
nikkadanny
Nov 19, 2010 07:25 PM
