High speed braking vibration
Help me diagnose. I have high speed braking vibration. Only occurs at 45+ speeds and vibrations can be felt in steering wheel and brake pedal. When I brake at slower than 45 I do not get any vibration
So deposits of the pad on the rotor? I will try sand paper. Also the rotor is free moving right? Just held on by the lug nuts and pad? I noticed that I can pull on the rotor to get it to wobble
Same thing happened to me today, I put new rotors and pads in, bed them in properly and over the last week it has been shuddering under heavy braking, I did a track day to day and it got worse as they got hot???
Try sanding the rotors with 180 grit wet dry paper until the rotors are nice and shiny on both surfaces. Sand the pads on a flat hard surface with the same grit paper to renew the surface on them. Then wash everything with Brake Cleen before installing.
Then re- bed the pads.
L8r
lznk41
17
May 2, 2020 07:18 AM
slicksta69
15
Jun 20, 2016 09:23 AM
