Lowering springs and suspension travel. You ARE hitting the bumpstops.
#33
At what point would a GTWORX Springs, HD Bilsteins, Whiteline swaybars f/r be overpowered in terms of tire width and compound?
I am currently running stock BBS rims with 245/45/R17 Starspec Z1s, GTWORX Springs (love them BTW), Front and Rear Whiteline sway bars.
I went with the GTWORX springs because I did not want the added cost of a roll center kit and they received good reviews. I even was able to speak to one of the owners (Miles I want to say, the SUbie guy. ) at length and I really appreciated the customer service.
#35
7/10ths = not pushing the car 100%. Here he's pushing it 70% of it's maximum potential (where he'd be running on the edge, tires squealing etc.)
@mayberry-> I grew up in Voorheesville.
#38
I was told I did not need the RCK with the GTWORX springs and HD Bilsteins. In fact this was the reason I went with their springs among other things as I didn't want the hassle. I'm not sure if installing the RCL will hurt/help though. I'll leave that to the experts.
#39
The RCK is helpful yes, but not a must have. It does make a difference that can be felt but the car is still awesome without it.
Bster, overpower is probably the wrong word to use. Our springs are definitely more ideal for a car on sticky street tires than they are on a car with 305 width hoosiers, but the car won't be groaning in pain like it would on stock suspension. R comps slot in between....with your front and rear Whiteline swaybars you've got an extra leg up and could definitely handle R-comps. There will be some roll, but the car will still be a blast to drive. With stock bars it would be much more noticeable but still acceptable in my opinion.
Thanks for the kind words! Glad you like the springs.
- Andrew
- Andrew
#41
just fitted eibach's with hd's poss the equivilant to the worx springs and dam the ride is good now. gone is the harshness , its noticably lower and no rubbing which was surprising with my tyre/rim combo
the evo is finely a very nice road car
#42
Wow, I completely missed this thread. Thanks for the kudos. Always glad to help.
I've got my front end all apart at them moment (trying to install a front sway bar and various bushings). I can try to measure the front bumpstop clearance once I have my control arms back on the car.
Sounds to me that with the smaller amount of travel to the bumpstop with the drop caused by the Swift springs, a beefed up front swaybar (along with a matching rear swaybar) would be recommended.
l8r)
l8r)
#44
This is going to be long and ugly. Sorry.
A lot of people understand that you can't drop an EVO (or most cars) 2 inches and expect the car to handle well. You lose bump travel and suspension geometry goes to hell. These drops are mostly for show unless the car has coilovers designed for that drop and geometry correction kits/parts.
But I don't think a lot of people understand how limited bump travel really is on these cars and how close these cars are to the bumpstops at even stock ride height.
(remember you have the weight of the car on these, and a big honking rubber/foam bumpstop in there too taking up space. bump travel gets used up quick even before you hit a bump or the car starts rolling in a turn.)
I measured bump and droop travel back when we designed our GTWORX lowering springs, but unfortunately lost all that data when my laptop was stolen last year.
A big thanks to Ludikraut and funks for helping me get these measurements again off their cars.
These are approximate numbers....not measured by me first hand but should be good. Also 1 inch of wheel travel is not exactly 1 inch of strut travel, but it's very close with a mcpherson strut.
Total stroke (bump + droop travel) is 155.6 mm or 6.125 inches.
Bump is 88.9 mm or 3.5 inches at stock ride height.
This is NOT including the bumpstop....which is about 2 or 2.5 inches long i think (anyone got an exact measurement? stupid moron that broke into my place has a LOT of useless info that probably doesn't make any sense ).
So that means that (calling the bumpstop 2 inches), you have 1.5 inches of bump travel before hitting the bumpstop. And you are hitting them....1.5 inches of movement is not much.
What happens when you "hit" the bumpstop? You probably don't feel the initial impact to be honest. They're actually designed to be engaged. Spring rate progressively increases....more and more rapidly, which means understeer. You can end up pretty far into the bumpstop actually, and the spring rates just keeps going up and up and up....
On my MINI and on a few other cars, the car is essentially on the bumpstops at rest. This means that the second the wheel turns, the car rolls onto progressively stiffer bumpstops. So you get AWESOME turn in, quick reactions and good feeling transitions. Similar to an EVO or Subaru with a HUGE front sway bar....awesome at up to 7/10ths or auto-x situations where steady state cornering isn't quite as important.
But this sucks *** (layman's terms) at the limit or anything beyond 7/10ths, as the spring rate spikes to infinity up front, you get massive understeer. Good for engineers designing a sporty car to "feel" good to most people and yet still be safe from underwear ruining oversteer. My MINI in stock form was kinda crappy when pushed really hard, but a total blast the rest of the time. It also sucks when hitting bumps.
Back to the EVO.....1.5 inches (assuming a 2 inch bumpstop, it could be bigger) before the bumpstop is engaged is not THAT bad compared to some other cars. You are hitting it at times stock, but as I said it's gradual at first. True bottoming out is when you actually bottom out the shock, which is pretty darn harsh and that's what you're feeling on big potholes.
(a stock EVO....very much on the bumpstops in a corner. world is not ending, but the car could do better.)
Now drop the car more than 1.5 inches and you're on the bumpstops before the car starts moving. And every EVO I've seen with a spring that drops the car that much has understeered massively. Not only that, but bumps, whether it's curbing at the track, mid corner bumps, or simple bumps on the street....seriously upset the car.
Cutting the bumpstops is an option, but it does have it's drawbacks. They're progressive....so cutting them means the impact when you do hit them (which you will) is going to be more abrupt and probably not pleasant. You do need the bumpstops there for those times when you DO bottom out the damper (which is obviously more likely when you lower the car 1.5 inches).
Swift springs lower the car 1.4 inches, which is more than I'm personally comfortable with....BUT they do add a some amount of spring rate over stock so even though you have a tenth of an inch or so before the bumpstop (need to double check that length), the added spring rate helps to keep the car off the bumpstops a little more. And the added rear rate helps keep the balance in check to an extent. This is why they are actually pretty decent when pushed (see SmikeEVO) and also why Swift Spec R's have ride quality that is not far off the Swift Sports....the Spec R's added spring rate at the same height means you're off the bumpstops a little more. But you're still on them, and you get on them fast.
Our GTWORX springs sometimes get crap because they only lower the car 20mm (about 3/4 inch) up front....and the cool "look" is more popular than better handling. Many people think we did it for ground clearance or suspension geometry....these were a concern but they were far behind maintaining bump travel. I wanted the suspension to be able to "work" and control the car with the springs as much as I could and avoid the super progressive bumpstops that ramp up super fast to inifinity lbs/in. Lowering the car just 20mm front and 15mm rear with a higher spring rate then Swifts means you are letting the dampers and springs "do their thing" as opposed to having the bumpstops come in and ruin the fun. It's more compliant and it handles better.
Good track suspensions are designed to avoid the bumpstops when possible....and to let the spring rate come from the spring. Better handling, better chassis control, more compliance.
Time for a beer. I had been meaning to post something like this for a while. Let me know your thoughts, observations, tell me i'm full of crap, questions, etc.
- Andrew
- Andrew
DAMN I may have to go with the GTWorks Springs!!!! Even the SPEC R's wil ruin my stock MR Struts? Do I need anythign other then the GT WORKS springs or a roll center kit?
#45
I'm not saying they'll ruin your struts really fast, but they are a lot closer to the bumpstops and it's lower then i think they should be. They will definitely wear them faster than stock and I bet they'd handle and ride better if they were say a 20mm drop up front like our springs.
Just the springs makes a nice difference, everything else is icing on the cake.
- Andrew
- Andrew
