All Wheel/Tire Fitment Guide and Questions Go Here - Page 240 - EvolutionM - Mitsubishi Lancer and Lancer Evolution Community
Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack Discuss everything that helps make your car start and stop to the best of it's abilities.
Sponsored by: Tire Rack
Thread Tools Search this Thread
Old Dec 5, 2017, 10:47 PM   #3586
EvoM Moderator
kyoo's Avatar
Drives: IX
joe,
how's the clearance on a 255/40-18 on an 18x9 +35? would i need to go 255/35-18 to still clear everything?
Offline
Old Dec 6, 2017, 06:58 AM   #3587
EvoM Super Moderator
Drives: 2006 ランエボ RS
Quote:
Originally Posted by kyoo View Post
joe,
Hi Sam
I like youre idea. Youre more in the "kill zone" with this spec. Ran your no.s using the 40 series. You will have a -2.71% speedo error but dont think youll need a fender pull.
Certainly a rear roll should do it. It may need to be a nice tight roll vs a 3/4" roll as some of us have. Dont think youll be needing the bumper bolt relocation either.
You know me, I like meaty tires, so the 40 series would be my choice.
Not sure what wheel this is, but hopefully no front spacer is needed
Online
Old Dec 6, 2017, 07:31 AM   #3588
EvoM Moderator
kyoo's Avatar
Drives: IX
Quote:
Originally Posted by MinusPrevious View Post
Hi Sam
it's a negative error? i thought 255/40-18 will be taller? i'm running 255/40-17 and it's very close to stock height.
i'm consdering getting some volks in 18x9 +35 to "start," just exploring some other options
Offline
Old Dec 6, 2017, 08:35 AM   #3589
Yes, definitely a taller tire but comes up as a neg due to the slower rotation. i.e. at 60mph you'll be showing 58.38
Online
Old Dec 6, 2017, 09:05 AM   #3590
EvoM Moderator
kyoo's Avatar
Drives: IX
oh, oh understood. anyway cool, thanks! so i'm assuming compared what i've currently got, the fitment should be roughly the same
Offline
Old Dec 6, 2017, 02:17 PM   #3591
EvoM Moderator
kyoo's Avatar
Drives: IX
sorry for all the requests - i realized i could just stuff the 265s on the 18x9 - i'm assuming in this case too the fitment is all around better. a little wider but much shorter, should still have rolled fender and bumper bolt clearance.
Offline
The Following User Says Thank You to kyoo For This Useful Post:
MinusPrevious (Dec 6, 2017)
Old Dec 6, 2017, 05:39 PM   #3592
Sure, the 265/35 works w/that wheel but I think the overall look & street performance is better w/the 255/40 (more side wall protection on the street & looks beefy)
But, if the 265/35 is your choice, it should fit OK w/a tight rear roll. The bumper bolt relocation may not be needed but it will be close (very dependent on rear camber setting). If you set your rear camber to -2.0 degrees, that will help a great deal
Online
The Following User Says Thank You to MinusPrevious For This Useful Post:
kyoo (Dec 6, 2017)
Old Dec 10, 2017, 07:54 PM   #3593
Drives: 06 Evo, 93 Eg
Is anyone running the new NT03RR?
I saw them for sale 18x9.5 +27
Not sure how the fitment would be or if I'd run into any issues w/ a 255/40 tire.
These would be going on my IX. I'm on Bilsteins/Swifts now, but will be installing a set of coilovers this spring.
I'm ok w/ rolling the fenders but nothing more than that. Also, I have mud flaps...and I really do not want to get rid of them.
Offline
Old Dec 10, 2017, 08:09 PM   #3594
Very popular wheel, but will need some aggressive rear fender work beyond the roll. You can certainly attempt just the roll (should be a flat roll) but a rear pull would likely be needed for a true, no rub fit
Also, due to running the +27 & the 40 series tire, you will have to relocate the rear bumper bolt
If you search Enkei NT03, there are many threads w/many comments. Front spacer will be needed (approx 12mm)
If you have further questions, let me know
BTW, the flaps will have to go w/that 40 series tire, Sorry =(
Online
Old Dec 10, 2017, 08:50 PM   #3595
Raptord's Avatar
Drives: AS Evo IX SE
Go with 255/35 if you can. I had to take off my mudflaps because they rubbed in the front at full lock with 245/40's (also on NT03's), so 255/40 would be even worse.
With 255/35 being almost 2cm shorter than the 245/40 I have now, I think they could fit without rubbing on the mud flaps.
And as mentioned by Minus, front spacer is needed (I went with 10mm and it's enough, so should be the same for NT03RR assuming spoke design is unchanged from the NT03+M) and there's a good bit of work needed on the rear fender. I'm running -3 front and -2 rear camber FWIW. I did the front DYI fender mod which I didn't need to make 245/40 fit, but I expect will be needed for 265's I hope to put on eventually.
Offline
The Following User Says Thank You to Raptord For This Useful Post:
MinusPrevious (Dec 10, 2017)
Old Dec 10, 2017, 08:59 PM   #3596
Thanks Raptord!
Online
Old Dec 11, 2017, 08:58 PM   #3597
kaj
kaj's Avatar
Drives: '06 MR, '00 Civic
Heres a view of this 10" wheel vs what youre running. I think the +40 offset will be getting into the lower control arm Most of the 10" guys are running +30 IIRC. The poke is about 1mm less than what you have now
Bump because I'm looking for a 10.5 wheel that will work. I'll drop down to a 10" wheel if i have to, though. I'd *like* to run a 275 tire.
My 17x9.5 +38 RPF rubbed the lower, rear control arms slightly... but an 18" wheel puts the rim farther forward, where there is more room. May work?
I've been up and down this thread and can't find where someone posted a 10.5 wheel that works LOL. Still reading, though.
**edit: it looks like the tire I want to run in a 275 is SERIOUSLY tall (40). Maybe I'd have to drop down a 265, in which case I guess I can stick with a 9.5 wheel and keep things simple.
Bummer. I was looking for a reasonable upgrade from a 255.
Offline
Old Dec 11, 2017, 09:09 PM   #3598
Anything over 10" is really out of my wheel house. 10.5 is way wide & needs major fender tuning which I dont think you want unless youre thinking about over fenders
Jason, This is a track wheel, correct?
Online
Old Dec 11, 2017, 09:22 PM   #3599
kaj
kaj's Avatar
Yes, sir. I suppose a 10.5 is unrealistic, seeing how my 9.5s were rubbing the CRAP out of my front fender liners with PSRS and an effective +13mm offset. LOL.
I don't mind pulling /cutting/trimming/ etc. I'd like to mount some cheap overfenders, but they are all kinda pricey and I'm not sure really all that worth it.
Offline
Old Dec 12, 2017, 06:55 AM   #3600
If your still going to street your EvO, then I would stick with the 9.5" wheel, keeping it clean looking.
The track guys sacrifice the clean fit w/the aggressive wheel/tire package
Online
Thread Thread Starter Forum Replies Last Post
Cam Install... Read this first. timzcat Evo Engine / Turbo / Drivetrain 129 Oct 30, 2017 05:46 PM
Official wheel/tire info thread Blacksheepdj Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack 327 Mar 13, 2017 12:15 PM
Tags
04, 10, 15, 17, 17x10, 17x9, 18, 18x, 18x10, 18x1038, 18x105, 18x10515, 18x8, 18x9.5, 18x95, 19x85, 22, 245, 24545, 25, 255, 2554017, 275, 29, 31, 35, 38, 40mm, 5x100, 5x45, 5zigen, 95, a4, advan, audi, b5, bbs, bmw, bolt, ce28, ce30, enkei, enkie, es, et38, evo, evolution, fit, fittment, fn01, fn01c, fn01r, fn01rc, grid, grid's, help wheel fitment, honda, ix, konig, konig lace, lace, lm, mazda, model, mr, offset, offset., pattern, perfect, pics, prelude, racing, rear, rgii, rims, rota, rpf1, rs, rsx, saab, sale, size, sti, strength, subaru, tire, tire size, tire size for volk re30, tires, tyre, volk, vw, wats, wheels, widebody, x85, x9
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
