Tire / Wheel Fitment Questions
Old Mar 8, 2018, 10:05 AM
  #3721
Astro_Train's Avatar
Yeah, certainly remember that RS w/the TE's. Thats how 17's are supposed to run
Did i read your post correct? You are in the process of running these wheels / 17x9.5 +28?
That spec is what i was running before going back to my track wheels in the post above (Advan 17x9 +29). My 9.5" are the Rota P45R 17x9.5+30 w/the Fed 265/40's
As you may know, we had to pull, roll & relocate the bumper bolt & run close to -2 degrees of rear camber. With all that work, there is zero rub at any ride height or compression bump
Keep me posted on what youre doing & post up a pic. I dont remember what your car looked like?
Joe
I figured it would take a good amount of work especially with a meatier tire. This was my last set up before the current. The CEs are up for sale. If you notice how skinny the Michelins (255/40) look on the second pic. The WEDs were 17x9.5 +32. The CEs are super aggressive... I wish the Evo 8/9s had the clearance the Xs. But so is life. The reality is I am almost 100% that I will run 275s.. I do not plan on dumping the car though so that should help. Appreciate the heads up.. can't wait.
-- Roger
and these are the CEs.. they are now off the car.
MinusPrevious (Mar 8, 2018)
Old Mar 8, 2018, 10:09 AM
  #3722
Received 1,384 Likes on 1,317 Posts
EvO is very clean Roger
Will look even better w/the meatier 275's
Joe
Astro_Train (Mar 8, 2018)
Old Mar 9, 2018, 02:23 AM
  #3723
dyablo's Avatar
Its hard to nail down the exact wheel spec youll need, but generally speaking:
18x9.5 +34 to +38 may be OK running a 275 w/just a tight rear fender roll
Offsets lower that +34 will likely require a bit more rear fender work (i.e. pulling, bumper bolt re-location etc). And certainly, in your case, being that this car sees aggressive track driving, any form of rub can not be tolerated
If youre at a point where you have zeroed-in on a wheel, I can give you a better idea on what work is needed.
As an example, my set-up is fully cleared for the track: 17x9 +29 & a 17x9.5 +30 (275/40/17's). This set-up needed the full compliment of rear fender work (rear fender pull, roll, bumper bolt & a few other tricks to get this to fully clear)
I'm either going with Enkei TM-7 in 18x9.5+38, or Enkei Raigin 18x9.5+35. just can't decide if i should go with the stock +38 over the 35. Starting with 255/40R18 RE-71 and looking to eventually move up to 265 maybe 275 if possible.
Opinions?
Old Mar 9, 2018, 05:52 AM
  #3724
Opinions?
Well, they are both nice looking wheels. I kinda like the Raigin! You have picked an aggressive wheel but your offset choice is right on the money (not too wild). Figure on a tight rear roll to get those to fit (tire size will change what is needed to fit)
Make sure youre on top of what is needed regarding front spacers (most Enkeis need a front spacer)
Any other questions, please let me know
kyoo (Mar 9, 2018)
Old Mar 9, 2018, 06:29 PM
  #3725
islaw's Avatar
Te37sl
18x10 +40 with pss 265/35/18. What spacers will clear all round?
Old Mar 9, 2018, 06:37 PM
  #3726
The +40 would most likely contact the rear trailing arm. Most 18x10'rs are running a +30 offset (did you want to add a 10mm to the rear to clear?)
Would not recommend adding any spacers to these wheels (fronts would likely need a large spacer)
What made you look at these wheels?
Old Mar 10, 2018, 06:47 AM
  #3727
Like MinusPrevious said, you would have a run a spacer up front and in the rear. If you are set on running an 10 inch version, Rays makes a +20 version (which does not require any spacers) but you would have to do a ton of work to run these on an Evo 8/9. You are better off running an 18x9.5 +22 and a 265/35 would fit properly vs being stretched on a 10 inch rim.
I did a bit of research on this size and looks like Rays wanted to make a concave face higher offset variation for the Subaru community since their stock offset on their cars is +53ish. So +40 is aggressive for them.
Here is the size caliper clearance link on Rays site for that wheel.
https://www.rayswheels.co.jp/product...n&wheel=TE37SL
Old Mar 21, 2018, 10:19 PM
  #3728
truitt's Avatar
Trying to find out if these would fit my 04 Evo 8. I don't want to run a spacer or anything like that. Looking for a decent tire size nothing to stretched looking.
Amazon Amazon
Buddy Club BC01-SFC189030514-BY 18x9 ET30
MinusPrevious (Mar 22, 2018)
Old Mar 22, 2018, 05:25 AM
  #3729
https://www.amazon.com/Buddy-Club-BC...=buddy+club+p1
https://www.evolutionm.net/forums/ev...thread-19.html
page 19 post 282.
this is what that member said..
Full fender work, no spacers, and no rubbing. KW V3's. Nitto NT05's, 275 35. -1.8F, -1.6R.
However.. he is running a 275 which is a bit overkill on a 9 inch rim.. a 255/35/18 is perfect for this size.. and as long as you do not dump the car you should be fine without having to roll the rears... But yes they do clear without spacers. They look nice too.
If you want to run a 265 then you will probably just be fine by rolling the rears. But anything above a 255 is not needed for a 9 rim.
truitt (Mar 22, 2018)
Old Mar 22, 2018, 06:45 AM
  #3730
Thanks Roger^^^^
Yeah, an 18x9 +30 is a fairly modest size for the CT9A rear end. Plan on a tight rear fender roll using a 255/35 or 255/40 tire. If this wheel was a 9.5" wide, you would be looking at more rear fender work (i.e. rear pull & bumper bolt relocation)
BC's are great wheels & have always been a fan of the Buddy Club P1 QF: Forged- 17x9 +28- 14.5 lbs. See below. (no spacers needed as reported by users)
Old Mar 23, 2018, 05:46 AM
  #3731
badev0's Avatar
Rota Torque 17x9 +30
Will these require spacers in the front to clear Brembos?
MinusPrevious (Mar 23, 2018)
Old Mar 23, 2018, 06:40 AM
  #3732
Heres a thread where the member noted that a front spacer is needed on these wheels. See here: https://www.evolutionm.net/forums/ev...wheeldude.html
Hey, Rotas are a good wheel for the street. I run the Rota P45R 17x9.5 +30 w/a 275/40 tire. No front spacers needed. There are a few Rotas where no front spacer is neeed. You may have to move to the 9.5" width to find a wheel that needs no spacer
badev0 (Mar 23, 2018)
Old Mar 23, 2018, 07:10 AM
  #3733
kyoo's Avatar
i think after i run the evo x wheels this season on track, i'm gonna ditch those and run konig hypergrams in 18x9.5 +35. any experience with those wheels/offset? it's not a bad looking wheel, i like it in matte grey. I weighed the evo x wheels as 22.2lbs, 19.4 for the hypergrams.
Old Mar 23, 2018, 07:58 AM
  #3734
Nice looking wheel Sam for the street & certainly a good size & offset for the EvO Rear. Ever consider a track wheel in 17"? (Advan, Volk, Buddy Club). My 17" Advans are 16.9#'s
Old Mar 23, 2018, 08:04 AM
  #3735
kyoo's Avatar
i prefer 17s... but after switching to the evo x brakes, i can no longer fit them
Quick Reply: Tire / Wheel Fitment Questions
