Where to buy NT03+m 17x9.5
I am looking for the best price on a set of these. Not really sure where the best place is to buy. I dont buy rims ever.
My other question is the +38 offset the bad *** offset for the evo? Because that is the only offset listed on the Enkei website.
With the +38 youll need a spacer up front to clear that caliper (from what I remember reading), and depending on tire width you may need a spacer to clear the trailing arm.
But, yes its what you want to run. You need a lot of offset in the rear to clear the fender and having equal f/r will let you rotate.
Too bad JLB isnt around anymore. That would have been too easy
BTW, TheBoz. Please add your RS to the gallery
https://www.evolutionm.net/forums/ev...ry-thread.html
I wasn't aware that they are out of production. From a utilitarian standpoint, they are very good wheels. Enkei says that they weigh 20.1lbs/wheel, and they are very strong.
People seem to prefer the looks of the concave look that many of the 18" wheels offer over the convex 17x9.5 + 38. I value an inexpensive 17" wheel greater than a better looking 18" wheel that requires more expensive 18" tires.
HERE are a few pictures of my car with the 17x9.5+38 NT03+m.
EvoM Community Team
Not true. NT03+m's in 17x9.5 + 38 will fit with no spacers. When using a 255/40 tire, they rub VERY slightly in the front wheel liner. By slightly, I mean that there will be a spot the size of a dime where rubbing can be seen.
I couldn't have said it better myself.
I don't know that the 18x9.5 comes in a +38. I know that there is a +27, and at least one more maybe two other offsets that people run. IIRC, the only way of running an 18x9.5 NT03+m without spacers is to run different offsets in the front and back.
