The Right Wheels for 285/35/18 RS3's?
so i really want to run the 285/35/18 Hankook RS3 for autocross, but i can't quite find the right wheel for it. i know i need an 18x10 but i just can't find one with the right offset, spoke clearance and price. i only want to spend right around a grand.
i'm running in ASP and our club gives a .975 street tire pax advantage. this also needs to be stock body. no widebody.
I would actually run a 10.5" wheel, but that is just me. (285 / 25.4 = 11.22 - 10.5 = .72 / 2 = .36") Something around the lower 20's for offset.
Maybe Enkei NT03+M part number: 36581056530SP, 18x10.5, 30ET, 21.0lbs, you should be able to run this wheel with a minimal spacer up front.
have fun fitting 285/35's on a stock body. 285/30's aren't too bad since they're shorter (and tons of autocrossers have known setups that work), but I think 285/35's are a lot of work.
I'm going to be running this size tire and rim. I am most likely going to buy Rota G-Forces. I wouldn't go below a +35 offset on a 10inch rim. Honestly +38 is more like the sweet spot. The wider the rim the higher the offset you need to go. A +20 offset is going to fit like ***. You're never going to get a 285 on there with that offset. It's going to rub bad.
You need custom rear end links - R/T Ernie makes a set that will allow you to run a wide rim.
-Note: If you do not have a custom rear trailing link I think the max you can go is around 265-275maybe and really depending on the tire choice.
You need to be between +35-+40 offset +38 I think is the best size.
You will also need to use a 15-20mm spacer up front.
You can get all this to fit with out rubbing issues. The rears need only a minor fender roll and the fronts need to be rolled. Go look up R/T Ernie's info on this.
I will most likely be running a 285 and stepping up to a 295 or 305. This can be done if you take your time and get the right stuff.
I didn't realize you wanted it to all fit on stock body when I first saw your post, but after seeing your second post and the suspension your running.. Your going to need a good amount of camber, and not going to get the car as low as you would want.
I run a 10" wheel with 255 tires and has to roll a little bit. I don't roll slammed either.
i definitely don't roll slammed either. it's a functional auto-x car. i eventually want to upgrade to muellerized ohlins, but not at this time. my main goal right now is finding less expensive alternatives to the rpf1 or nt03, which is looking like i'm not going to.
I made a typo and put lower 20's, when I meant lower 30's, hence why I suggested ET30 wheel..
Also I forgot to mention you need a 6" spring or be able to set your preload to 6 inches so you can clear the rim/tire.
Why would you want to run the 285 in that tire? The 275/35/18 has a thread width of 10.2" where the 285 is 0.1" more narrow at 10.1".
More importantly though, the 275 is 0.3" shorter then the 285, which will help with fitment. The biggest problem you'll have with fitment is running the tire into the rear of the wheel well and side skirt while turning and a larger diameter will only make this worse.
As far as offset, personal opinion, a 9.5" x 22mm offset puts the wheel face about perfect with a pulled fender. That would mean ~+34 offset on a 10.5" wheel. Not sure what wheels out there clear the Brembos in 10.5" with that kind of offset though. Also, you are pushing the inside of the wheel towards the strut with that offset so you'll have to balance the camber adjustment ont he strut with wheel clearance and then use camber plates to get your desired camber angle.
I would be more concerned about rubbing the rear end link. You don't need to pull and destroy your car to get a +35-+38.
If the OP is racing his car I would hope or assume he has camber plates.
FS[SouthEast]: NC: Fully built 2008 Evo X GSR
GrkBallaG
For Sale - Cars For Sale
Aug 11, 2016 06:20 PM
FS[Northeast]: 18x10.5 Enkei RPF1s + 285/35 Hankook Ventus RS3 V2's
CooperS7777
For Sale - Wheels / Tires
Apr 25, 2016 05:31 AM
Roen
Apr 10, 2014 12:34 PM
