HELP! Front end clicking/clunking/popping
Hi Guys,
I have been searching the forums for about 2 weeks trying to find the answer to this one. This is my last ditch before I take it in to a shop. Lots of threads out there on front end pops, clunks, and clicks, but after jacking up the car 6 times in the past 12 days, nothing has fixed the problem. First here's a video documenting the sound:
2006 Evolution IX SE, stock powertrain, stock suspension. No heavy impact or curbing that created the sound.
The sound occurs intermittently with no real regularity-- usually it sounds like it is front passenger side, but occassionally I will think I hear it closer to the middle or driver's side. It happens when I hit a low speed bump with the wheel turned. It happens when I start off from a stop. It happens when I brake aggressively. It seems to occur both with the clutch engaged and disengaged, both with brakes engaged and disengaged, both in gear and out of gear.
I think the sound started before my last big install, but became noticeable after I recently installed Girodisc two-piece rotors and a Beatrush undertray. I've checked and rechecked the torque on all of the bolts I removed during those installs, checked the brake pads several times.
I attempted to "shake" the wheels top to bottom and side to side to detect any play in the suspension-- no luck.
Car drives normally, with no detectable change in performance.
I'm at a loss. I really hope you guys can help me. My last option is to take it in.
Thanks for the help!
Rob
Rob
Fixed it. Apparently I dislodged the power steering line either when I installed my Beatrush undertray, or when I was running the wires for my oil pressure gauge. Anyway, the power steering line was rubbing against the subframe and making the noise. No damage-- fixed!
I would just follow the power steering line out of the reservoir and check to be sure it isn't hanging loosely anywhere on it's route to the steering column.
Rob
Wow, this was such a long time ago, I totally forgot I had this issue... If I remember correctly, it was best accessed under the car. About the same position as oil pan/filter bu closer to center.
Rob
Rob
