Anyone interested in "drop spindle" uprights?
Old Oct 22, 2016, 11:52 AM
  #196
Benja258's Avatar
Originally Posted by Dallas J
Right now, only on my shop floor. It's not as light as some of these other ones offered but I've put a lot of work to make them stiffer than stock, 2" of roll correction (plus 0.65" with WL roll center kit), and bump steer correction.
i'll think we all be happy if you let us know how it runs anf if you considering to market them
Old Oct 22, 2016, 12:09 PM
  #197
V.8MR's Avatar
That beautiful...
Old Oct 22, 2016, 12:22 PM
  #198
Dallas J's Avatar
I made 10 sets of these for the racers here and have been running the original prototypes on my car all summer. Right now I'm just waiting for the last bits of hardware. Fixing the roll center and bump steer has been pretty magical.
Old Oct 22, 2016, 02:29 PM
  #199
marck_c's Avatar
How much $$?
Old Oct 22, 2016, 02:43 PM
  #200
Dallas J's Avatar
It's not cheap, but Im doing my best to balance price vs paying myself back which is about all I really care to do. Id have to eventually sell 30sets to fully pay myself back but I'm pricing the first batch of 10 at $1750. If I did a second set they would be $2000.
Old Oct 22, 2016, 03:39 PM
  #201
marck_c's Avatar
Thanks Dallas. And the weight...?
Old Oct 22, 2016, 08:25 PM
  #202
Dallas J's Avatar
I started out about 5lbs lighter than stock but I decided to add a bit more weight back into the uprights as a trade off to make the part stronger/stiffer than stock. So the 1lb sacrifice to increase a couple bolt diameter and add material I feel was worth it considering this is a part that literally connects the wheels to the car through suspension. So in the end its 4lbs lighter than stock per side.
Old Oct 25, 2016, 09:53 AM
  #203
hispanicpanic's Avatar
On my racefab arms i've corrected front roll center by 16mm. It definitely makes a huge difference but now the car is out of balance......
The rear end needs some roll center correction in order to bring the geometry back to a neutral balance.
Is the car faster like this?? I don't know.... its a big maybe... but i didn't correct the bump steer like Dallas did which i suspect to be the biggest benefit in modifying front geometry.
Dallas, love the way you correct tie rod pickup points as low as possible. Just one more thing.... In order to get a proper zero on the bump steer you're gonna have to lower the steering rack. Not sure there's a way to do it without getting a custom subframe.
Old Oct 25, 2016, 11:18 AM
  #204
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
If you changed the lower arm outer pivot without correcting bump steer, your car is all kinds of out of whack..
Old Oct 25, 2016, 11:42 AM
  #205
Dallas J's Avatar
I actually don't think the rear needs any roll correction regardless, My opinion always has been the rear is too easy to gain grip in typically needs to lose it. This is made even more evident at higher speeds when rear aero is far easier to achieve than front.
Basically my approach is to go the front roll center near ground and let the rear drop to greater than that. With greater rear roll moment I *get* to use more rear bar. The combo of high front and low rear roll center means we don't dive on the outside front so the inside rear stays down allowing more rear bar before the tire lifts. All that leads to the front inside tire doing more work. Its all about getting that inside front working harder.
Bump steer was also something that took a real aha moment for me. I set the bump steer based on my models of the upright which were all just straight up but I realized caster changing the angle of the upright. So I set the spacing and position of my bumpsteer based on working for 3.5 - 7 deg of caster and stock and whiteline ball joints. There is no need to lower the steering rack IMO, its easy enough to get the position of the arcs to match up within our actual usable steering range. And also, with the roll correction with less dive, theres less steering changes to worry about.
The current steering arms will also work with the 16mm extended studs (same as the whiteline correction) when I make the billet control arms and shoot for 8 degrees of caster. But that's all TBD as I figure that part out.
Old Oct 25, 2016, 01:38 PM
  #206
RJones's Avatar
In for a set of those too
Old Oct 25, 2016, 02:14 PM
  #207
03whitegsr's Avatar
Great work man. Looks like you could play with the length on the strut mount too and could change slider angle and scrub, particularly if you add some control arm length to this system.
Old Oct 25, 2016, 02:38 PM
  #208
Dallas J's Avatar
That was also part of my reasoning for a modular design. Basically I've been thinking if someone wants something truly custom on that, I could either setup a few options or just create an open template for people. Like if you wanted to pull the strut in or push it out some distance or an angle change, then we could just accommodate.
My local SM buddy in a 240sx may get a slightly revised set of uprights where I just change the bolted on bearing to a 300zx part. Would also need to adjust bumpsteer range for him, but it would just be a side project bartering for a custom wing. With my design I can make relatively quick changes and get it setup for other strut configs.
I may try and make an ultra light weight version similar to the Girodisc brakes that are an AutoX (and maybe my car only) and not suitable to crazier open track build. For now, I'm completely satisfied with the strength of these as is now though.
Old Jun 30, 2017, 04:27 PM
  #209
TougeGod7's Avatar
sub'd
flyingscot
25
Jan 17, 2014 05:51 PM
nollij
Jun 3, 2013 03:44 PM
MREvOTard
Jan 3, 2008 01:01 PM
ultimatesteve
Aug 31, 2007 09:55 PM
crypto
17
Jul 28, 2006 10:31 AM
Quick Reply: Anyone interested in "drop spindle" uprights?
