225 / 40 / 18" tyre pressure track / street
who uses what? Thanks AK
P.S. Michelin Pilot Sport Cup2 (o/sized) mounted on 8.5" rims if it does matter
suspension is Ohlins R&T
alignment is stock
alignment is stock
225 width tire is the narrowest tire recommended for the 8.5 wide wheel. Way too small for the EVO IMO.
As far as pressures go, stay w/the recommended settings for street (i.e. 32 psi)
Track pressures depend on what type of track youre running. If the track is high speed, above 120 mph w/aggressive brake zones, starting cold pressures at 30 psi might be a good place to start. That skinny 225 tire will certainly get warm if pushed hard, especially on stock alignment
Joe
first of all these are semi-slick street legal racing tires and they come wider than "normal" 225
second steering is sharper with narrow ones
i'll play with a pressure and if i won't get feeling i want i may go for 235 /40 or 245/40 ones
GOKEN9
Dec 20, 2008 11:30 AM
mscorei
Oct 17, 2007 09:28 AM
