Looking for a good performance wheel size and offset, with good tire combo.
Old Apr 4, 2017, 07:39 AM
Welcome2GoodBur's Avatar
I'lol make this short and sweet. I have searched but all these threads seem to turn into who is running the most extreme tire setup/how far someone has pushed their wheels etc
I have a IX Mr sitting on Ohlins Coilovers (love these things). Looking to replace the wheels it has currently (Evo X GSR Enkeis - 18x8.5+38, on 245/40/18).
Debating on switching back to 17, or staying with 18. I am looking to most likely run RPF1, in a wide 9.0/9.5 or so. I like the look of the +15 (want something aggressive), but I do not want to look riced out or affect performance.
Car is not tracked....but I do daily spirited drives on the street
1.) what would be an appropriate wheel offset/ size and tire size for my goals?
Thanks to any input
Old Apr 4, 2017, 08:14 AM
Received 1,384 Likes on 1,317 Posts
Well, the +15 should be ruled out. No good way to make those fit properly in the rear
One of the most tried / true RPF1 setups is the 17x9.5 +38 running a 20mm front spacer
Heres a pic (he is active on the boards here if you need more info)
Welcome2GoodBur (Apr 10, 2017)
Old Apr 4, 2017, 11:02 AM
C0dyix's Avatar
Currently running 18x9.5 +22 te37 SL's with no rub. Tires are 235/40/18. Pretty in love with how it handles on better/wider wheels and tires
Old Apr 4, 2017, 02:35 PM
LetsGetThisDone's Avatar
Received 1,542 Likes on 1,321 Posts
Go with 18x9.5 +38, and 265/35r18 tires. You'll need a front spacer for strut and caliper clearance (20mm most likely), and 3mm rear spacer will give more room to the trailing arm. The rear fender will need to be fully rolled. This is the best looking fitment for these cars IMO, and getting it to fit isn't overly difficult,
Old Apr 27, 2017, 12:56 PM
Would the tire size 265 or 255 be more appropriate here on the 17x9.5 setup, if looking for the most aggressive yet functional setup I can achieve
Thank you for the input
Old Apr 27, 2017, 01:07 PM
The tire size ranges for the 9.5" wheel are 245 to 275 (255 & 265 fall right in the sweet spot)
Im a wide tire guy so, if your rear fenders can take it, I say go w/the 265's
let me know if you have other questions, Joe
Welcome2GoodBur (Aug 13, 2018)
Old Apr 30, 2017, 04:15 PM
Spoolin4g63's Avatar
I just purchased a set of TC105N's 17x9 on 255/40/17 NItto Invo and love it.
Old Jun 8, 2017, 08:44 PM
mrfred's Avatar
I'm a bit late adding my 2 cents, but 17x9 with +30 to +35 offset paired with 255/40-17s fits without rubbing anywhere even with coilovers. Max performance tires tend to run a little wider and may require closer to +35 mm offset. I'm running Enkei PF01SS rims that are 19 lbs each and currently currently at +32 offset using a 3 mm spacer. Its a nice combo because good 255/40-17 tires are much less expensive than comparably wide 265/35-18 tires.
Welcome2GoodBur (Jul 10, 2017)
kensuke
92
Apr 12, 2015 10:44 PM
urbanknight
41
Jan 11, 2014 02:58 PM
booster9
Jan 19, 2009 10:18 PM
Gruppe-S
Evo 'For Sale' Engine Internals and Drivetrain
Feb 16, 2007 01:07 PM
morpheus256
Feb 12, 2006 08:20 PM
Quick Reply: Looking for a good performance wheel size and offset, with good tire combo.
