Personalized question: Custom alignment needed or not
I will preface this with saying "I know, search is king" but I wasn't able to find the exact answer, so I figured I'd ask here.
I'll be taking my car to the suspension/tire shop this week, and could use some advice
I will have them mount my new ContiExtremeContactSports that I just picked up, but I am also planning to get an alignment while there.
What should I keep in mind when providing my alignment specs? How far off stock would I need to go based on the below setup?
Thanks in advance to any constructive feedback I get!
My setup:
Evo 9 on OHLINS coilovers (Have camber plates as well)
Evo X GSR wheels (18x8.5 +38)
Continental Extreme Contact Sports
Intended use: "Daily driving" - I drive pretty aggressively/ how these cars should be driven.
Thanks!
My setup:
Thanks!
Couple of options
You can set up the front camber as totally stock & get the best tire life @ − 1°00' ± 0°30' or go a bit more aggressive @ − 2°00’ ± 0°30’
Set the rear at the stock value = − 1°00'
Rear toe spec = .12 "
Front toe spec = Zero
Most of us just run zero toe front / rear
The following 2 users liked this post by MinusPrevious:
Is2scooby (May 19, 2018),
Welcome2GoodBur (Jul 24, 2018)
Couple of options
MinusPrevious, I hope someone supplies you with beers for all the times you have answered. Thank you good sir! I appreciate the input.
a904dam
Feb 18, 2004 06:10 AM
