whats the best offset for evo 9
Old Aug 23, 2017, 08:53 PM
hanko's Avatar
2006 mitsubishi evo 9
Old Aug 23, 2017, 09:04 PM
Pal215's Avatar
It depends on the wheel width and design, but you'll usually be around +20 to +25 for best performance and looks. 18 x 9.5 +2_ in most cases is excellent.
Old Aug 24, 2017, 05:04 AM
hanko's Avatar
thanks for that
Old Aug 24, 2017, 11:31 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Not really. 9.5" wide wheel is optimal for our car, but the offset needs to be around +35.
Old Aug 24, 2017, 07:29 PM
Received 1,384 Likes on 1,317 Posts
^^^Let the function speak the truth
Old Aug 27, 2017, 05:15 PM
hanko's Avatar
yeah cause wanna sell my meisters and buy some te37 s
Old Aug 29, 2017, 07:35 AM
Astro_Train's Avatar
actually I would say a 17x9 or 18x9 is the optimal size for the CT9A without having to do mods to your fenders. Offsets in the range of +30 to +35.
A 9.5 rim, even at conservative offsets and running a 265 which would be what most functional oriented folks will recommend will cause rubbing even when the car is lowered conservatively (say with Swift Springs on stock struts).
If the TE37 is what you are looking at and you want the concave face, the best option are the TE37 Sagas as Rays has changed the offsets a bit around on this wheel to allow more concave for lesser aggresive offsets.
Normally you have go with an offset of +22 to get the concave face on the standard TEs and its SL variant.
If you look at the chart for the Sagas on their site, the 18x9.5 +31 now comes with the concave face and the offsets is much more forgiving then a +22 when trying to get them to fit with a proper size tire... say a 265. Even with a +31 you may still rub in the rear depending on how low your car is. Also, I mentioned the +31 because according to their chart they will clear the calipers up front.
https://www.rayswheels.co.jp/product...wheel=TE37SAGA
Old Aug 29, 2017, 03:40 PM
Wheel fitment isn't optimal until you've maximzed what the fender can fit by rolling the lip and relocating the bumper bolt. Both are simple mods that, if done correctly, are invisible.
Old Sep 7, 2017, 01:25 PM
NewEvoGuyInFL's Avatar
Can anyone share pics with the different off-sets?
Thanks!
Old Sep 7, 2017, 06:48 PM
Thanks!
here are 500 pages in this thread... knock yourself out.
https://www.evolutionm.net/forums/ev...el-thread.html
Old Sep 11, 2017, 08:41 AM
mrfred's Avatar
Your least expensive route for a wheel/tire combo with bolt-on fitment that adds performance and looks will be a 255/40-17 tire paired with 17x9 +29 to +35 mm offset wheels that clear the front caliper without spacers. 265/35-18 paired with 18x9 wheels in the same offset will fit too, but will cost a hell of a lot more money. Well, at least the tires will.
Old Jul 18, 2020, 09:54 PM
Crzykdd's Avatar
Ive been doing some looking around about putting new wheels on my 9, are you referring to the bolt in the front fender? Also is it mostly just the rear fenders that need to be rolled, or the fronts too?
Thanks!
-Jason
Old Jul 19, 2020, 08:19 AM
Thanks!
-Jason
Most of the serious work involves the rear. Rolling the front alum fender is super tough due to the memory in the alum material. The fronts are very forgiving except for the liners. Liner mods are usually needed. Heres a pic of the rear bumper bolt relocation
Old Jul 20, 2020, 12:36 PM
Crzykdd's Avatar
Thanks, I suspected that was the bolt I, i saw that when I had to remove the bumper to replace the headlight bulbs. Also I noticed the lip on the rear fenders. So relocated front bolt, and roll rear fenders then.
Also I'm also just running drop springs, so my clearance with the front strut is limited on the inside, as it is with a 17X9 +35 rim with 255/40/17 tires I can barely squeeze a finger between the tire and the front strut. Was looking at a 265/40/17 tire but It doesn't look like there would be room with the current setup!
-Jason
EVL!EVO
Feb 22, 2022 10:13 PM
r-evolution
Apr 20, 2007 04:48 PM
NocturnalEVO
24
Jul 29, 2005 06:54 AM
ringmaster
Dec 22, 2003 11:17 AM
Quick Reply: whats the best offset for evo 9
