Loud squeal driver's side front when braking at low speed with moderate pressure
Old Nov 15, 2017, 01:51 PM
Bhsj13's Avatar
https://www.extremepsi.com/store/pro...roductid=31109
Here ya go!
Old Nov 15, 2017, 03:03 PM
barneyb's Avatar
The FSM says to use grease on both sides of the metal shims. I find that when the grease has been on there a long time I start getting noise.
Old Nov 16, 2017, 08:55 AM
Kreeker's Avatar
Originally Posted by Bhsj13
Thanks I placed an order last night. They only had 2 left !!
Sorry for asking so many annoying questions, but can you guys please explain how you are attaching the OEM fiber shim? Are you using any grease or glue between the metal shim and the fiber shim? Or just simply placing the fiber shim on top of the metal shim?
Old Nov 16, 2017, 09:27 AM
Received 1,384 Likes on 1,317 Posts
We should be following the service manual here: Appears to show adding anti-squeal lube between the pad the angled shim. The angled shim is directional (look for arrows) & should be the most outer plate up against the piston.
Also, the service manual shows how to remove the piston boots
Old Nov 16, 2017, 11:27 AM
goBYeBYe's Avatar
I just started hearing the high pitch squeal myself this last week. It didnt make that noise last few weeks.. Im not sure if the weather temp has something to do with it but the temp did just drop 5-10 degrees here in NY.
Old Nov 16, 2017, 11:39 AM
CaptainSquirts's Avatar
I am using ferodo ds2500 pads on slotted brembo rotors. I have the girodisc anti noise pad shims with the angles shims with a Disc brake quiet fluid/sticky type of substance and they still make noise at low speed/light braking.
Old Dec 4, 2017, 11:16 AM
Kreeker's Avatar
So this weekend I finally got around to re-installing the brake pads with angled shims, and I'm still experiencing the squeal (although it seems to happen less???).
For the front pads, I installed the angled shims with the arrows facing down. Is this correct?
One thing which I just realized, is that I didn't grease between the angled shim and the regular shim.
I think I'm at the point where I'm going to just have to go to the mountains and completely burn in the brakes. I've heard of stories where people say after a few thousand miles the squeal goes away...
I'm also wondering if this one rotor has some imperfections that is causing the issue because I only hear it from one wheel.
Old Dec 4, 2017, 11:24 AM
The arrow indicates the rotation of the wheel end. (important its oriented correctly)
Yes, lubing in pins & plates may help. And maybe a re-bed is in order
Old Dec 5, 2017, 06:48 AM
I cleaned off my disc quiet sticky residue from the pins/plates and used copper antiseize. It seemed to help with the squeal but we'll see over time.
Old Dec 5, 2017, 12:15 PM
barneyb's Avatar
I use multi-purpose grease I buy in tubs at any auto store. The grease quickly loads up with brake dust and dirt, becoming an asphalt like material. Plain grease and the angled shims are all I've needed for quiet brakes.
Chad & Jess
Jun 12, 2014 03:27 PM
vivac2
Mar 12, 2013 09:52 AM
sliqdaddy91
14
Jun 24, 2009 05:07 PM
02izzel
Mar 3, 2009 12:50 PM
Quick Reply: Loud squeal driver's side front when braking at low speed with moderate pressure
