Evo 8 bushings
Evo 8 bushings
Somewhat new to the evo world, former STi owner and happily came to the dark side. However my STi out handled my evo, so part of my winter plan is bushings/sway bars. I cant seem to figure out all the bushings and what not in this car!
Im looking to purchase the energy suspension bushing kit below along with sway bars
Also plan on doing some shifter bushings while im at it!
https://www.maperformance.com/produc...BoCVZoQAvD_BwE
My question is, is there any more bushings i should look into doing while i have the arms/links and so on out? And could someone show me on a diagram what all bushings are actually being replaced with this kit? Should i look into doing more? The names have me confused!!!
That kit looks rather complete & is likely all you will need unless there are other issues
You noted an interest in up-rating the sway bars. The EvO really doesnt need a front sway bar upgrade if you up rated your suspension springs.
Most of us run the Whiteline rear 24mm bar, but there are other RSB's avail
janderson13 (Nov 29, 2017)
Thank you for the insight! Maybe ill start with a rear bar and if its not enough, simply add the front later!! Im interested in also putting bushings in the arm where the coilover bolts into the rear suspension! Also some shifter bushings, steering rack as well! I know some of the factory bushings a spherical and theres no need to replace them!!
MinusPrevious (Nov 29, 2017)
https://www.viamoto.co.uk/prodimages...ed-diagram.jpg
could someone circle what bushings in the picture are replaced with the kit? And any others I SHOULD do while im at it?
http://www.streettunedmotorsports.co...mr403464_2.jpg
As well as this ? I know the one bushing is spherical ? Are all of them spherical? Are any of these worth replacing?
janderson13 (Dec 2, 2017)
MinusPrevious (Dec 2, 2017)
Yes Sir, i think youre right:
front & rear control/trailing arm bushings, 24mm front sway bar bushings, 22mm spiral rear sway bar bushings, rear differential bushings/mustache bar bushings
The kit is a bit diff than the WL individual bushings. i.e. like I noted, most track guys run the WL bump steer correction kit (just a thought. Not needed if youre not tracking hard).
And in the current state of my EVO (off track for 2 years) I certainly didnt need it
TWM Performance
Vendor Classifieds
Oct 31, 2011 02:16 PM
TWM Performance
EvoX 'For Sale' Engine Internals and Drivetrain
77
Aug 26, 2011 01:52 PM
RallyartRob
May 2, 2011 08:25 AM
Henster
May 7, 2008 09:07 PM
