Tire circumference and the center Diff
I know that all 4 tires need to be basically the same circumference to avoid damaging the center diff. My question is how much difference is too much? I want to play around with staggering tire size front to rear, but the sizes I have picked out are 2/10ths of an inch different front to rear. Is that enough to screw up the diff? This setup would be used for track days and auto-x only.
Greg-
You should be OK. I know of a few DSMers doing this not only at the track, but daily driving as well. I don't recall the exact size differences at the moment, but your .2" seems reasonable. <Insert disclaimer here.>
Our Tech Center has as great page on matching tires on 4WD vehicles. Heres a part from that page that might answer your question:
"As an example of different tire diameters resulting from tires worn to different tread depths, we'll compare two 225/45R17-sized tires, a new tire with its original tread depth of 10/32-inch and a second tire worn to 8/32-inch of remaining tread depth. The new 225/45R17-sized tire has a calculated diameter of 24.97", a circumference of 78.44" and will roll 835 times each mile. The same tire worn to 8/32-inch of remaining tread depth is calculated to be 1/8" shorter with a diameter of 24.84", have a circumference of 78.04" and will roll 839 times per mile. While the difference of 1/8" in overall diameter doesn't seem excessive, the resulting 4 revolutions per mile difference can place a continuous strain on the tires and vehicle's driveline. Obviously, the greater the difference in the tires' circumferences, the greater the resulting strain."
CityTireOnline
Evo 'For Sale' Suspension / Brakes / Handling
Aug 17, 2009 08:06 AM
robbunker
Apr 12, 2009 07:57 PM
Tractionlimit
17
Aug 9, 2008 03:51 PM
Hedonic Tread
15
Jul 16, 2004 11:06 PM
