18 inch wheels
Guest
Posts: n/a
18 inch wheels
When you get 18 x 8.5 inch wheels, make sure you get 225x40/18 tires for it. This will have the same rolling diameter as the 225x45/17 tires. Anything wider and the tires will touch inside the wheelarches.
This even happens with some 17 inch tires in 235x45/17. Not all tires have the same sidewall design, so one tires can be fine in 235x45/17, another cannot.
Also keep in mind that the wider the tire, the heavier. And the point is to reduce unsprung weight. There will not be a noticeable difference between 225 and 235 tires roadholding wise. So play it safe so to speak.
Love,
Love,
claudius
good point, lucky for me i was talking to a guy in ralliart
who mentioned fitting the wider tyres would scrub the arches,this
was before i placed an order for wheels and tyres,
as you said to get 18x8.5 wheels and 225x40/18 tyres are he ones i've chosen, can't wait to get them on the car!!!!!!!!!!!!!
claudius,
the makers of the wheel are khan and the model name is rs-r.
i could'nt find a khan website but check out this site.
http://www.supremepowerparts.com/khan.htm
ps. its the 5 spoke wheels.
tell me what you think of them.
Guest
Posts: n/a
I think it's a nice 5 spoke wheel, but personally would find it more of a match for a Golf or BMW 3 series. Looks too much like a street type wheel, not rallye style, if you know what I mean.
They look more or less light as well. You will be able to show off your brake setup with those as well!
Have you got more info on this wheel? I guess they are 18x8,5? How much do they weigh?
At the Motorshow in Essen I saw a 6 with 245s on 18" ATS wheels. It also had an Öhlins uprated suspension and had what looked like a 5mm spacer. The Öhlins suspension was a twin-tube damper which was designed to use the standard springs, therefore shít. The car was prepared by Gassner Motorsport and the suspension by a company called Zuben, or something.
Must have been installed by Zuppin the Oehlins importer in Germany.
BTW I had this Khan wheel on my Scoob but got rid of it as the offset wasn't correct.
Mike
Mike
Jonno99
19
Jan 23, 2016 09:17 PM
Jonno99
10
Dec 9, 2015 11:41 PM
alleggerita
10
Nov 25, 2015 11:58 PM
DsmEvo87
20
Aug 18, 2015 08:14 AM
WheelDude.com
Evo 'For Sale' Wheels / Tires
13
Dec 22, 2007 11:44 PM
