Suggestions
Suggestions
I have a 03 with tanabe type S springs and stock struts. My question is should I upgrade the struts along with anything else? I love tight corners and taking them as fast as possible so I would like to know what other suspension parts are needed to make this handle like a dream. Does a damn good job stock but im sure it can be better!!! Also with a drop like this is it a good idea to move up in size on the the wheels to like a 18x8.5.........wouldnt want any rubbing!!!! My alignment is not great either even though I have had it adjusted should I envest in a camber kit or is NTB just not doing a good job.
Because NTB said so................lol. They pointed out unusual tire wear. Which is frustrating because I balance and rotate my tires every 3000. Maybe just a bad bump, I have driven it to NY since my last alignment and damnit if those rodes are not F$%^&^
Have you had it aligned since you put the springs on? If so, do you have the specs after they aligned the car? If not, that is something I would look into soon.
-Ron
-Ron
