06 Evo IX factory camber specs?
What are the factory camber specs for the 06 Evo IX?
With the Swift springs, what type of camber would I want for a everyday driven car? I've heard -1.5 in the front and -1 in the rear with 0 toe. Is that accurate?
Originally Posted by broeli
You heard right. For best overall handling have them max the front which will give it at least -1.5 and do the rear around -.9 with 0 toe.
I read somewhere that -1.5 may be a bit for hardcore drivers for the fronts, so then I figured -1 all around with zero toe, or maybe -1 in front with -.5 in the rear.
But am not sure at all at this point
I run -1.5 degrees of camber in the front and -1 degree of camber in the rear, with the toe zeroed out all around. So far, not much, if any, rollover on my tires after 9 auto-x events since I've had the car aligned to these specs. The car is also my DD so I didn't want to get too aggressive with the alignment. Hope that helps
Aby@MIL.SPEC
15
Apr 10, 2018 05:12 PM
iodine23
42
Aug 17, 2013 08:57 PM
