extended wheel studs-q's and source
Old Sep 29, 2006 | 07:18 PM
555R's Avatar
i ve been thinking of going this route
and then found that evo studs are 12x1.5
same as honda
which i happen to have a set of honda studs also
if i remove the fronts
is the area/hole that they get pressed (the knurled area) into the same size as honda/acura?
\i find you can hammer them out and then use nuts to kinda press them in again
does that apply for front and rear
or should i just get a shop to press them in properly---removal of the hub
where are you getting your ext wheel studs also
Old Sep 29, 2006 | 07:38 PM
Speed Element's Avatar
H&R 15mm spacers come w/ extended studs.
You can also look into KICS wheel spacers. These come extended studs onto the spacers already. It makes installation a breeze. I use both on my current setup (18x9.5 +27mm NT03M)
Old Oct 8, 2006 | 03:54 PM
06 MR's Avatar
hey does anyone know a price on the spacers and extended studs and also special lug nuts will be needed also ??
Old Oct 16, 2006 | 06:25 PM
eddie's Avatar
Check out ARP wheel studs as well. They're supposed to be very strong. I used the Project Kics extended wheel studs and broke 4 of them at the track.
Old Oct 17, 2006 | 05:09 AM
kekek's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=219527
nickemangione
Mar 23, 2016 02:35 PM
vtluu
25
Mar 31, 2013 02:39 AM
Sly Moose
11
May 27, 2011 06:33 AM
Tsurara
Sep 29, 2007 04:27 PM
evodave
Jul 13, 2005 11:04 AM
