Wheel Fitment PICTURES ONLY Thread
#91
Wheels: 17x9 29offset Advan RS dark gunmetal
Spacer: none
Tires: 255 40 17 Bridgestone RE050
Suspension: Swift spring
Fender: rear rolled
Spacer: none
Fender: rear rolled
#93
Advan RG2 are 18x9 +29 245/40/18 Robispec Apexi Coilovers No Body Mods
Enkei NTO3+M 17x9.5 +38 Front 20mm spacer Rear 2mm spacer 275/40/17 Front fender stretch rear fenders rolled (My car was at HB meet)
#94
Volk TE37's in Bronze on RR
I like being original.
Specs:
Volk TE37
18x9.5 +22 offset
255/35 18 tires
Rolled the rear and now have no rubbing. No rolling in the front. No spacers front or rear.
I have Megan Track CO's but don't know the exact drop.
Specs:
Volk TE37
18x9.5 +22 offset
255/35 18 tires
#96
Wheels: 17x9 +35 CE28N's
Tires: Bridgestone RE050A Pole Positions 255 40 17
Suspension: Zeal V6's
Alignment: -1.5F, -1.0R, 0 toe
Fenders: No work done (no rubbing either)
EDK (Apr 19, 2020)
#99
wheels: 18x8.5 +30 Volk ce28n's Diamond Black
tires: 245/40ZR18 Falken Azenis rt-615's
fenders: no fender work required
suspension: Tanabe gf-210's
rgII's on the black evo are 18x9, gtr face (w/e offset that is), with 245/40's.
#100
owner ChrisW
wheels: 17x9 +35 Buddy club P1 QF
tires: 275/40ZR17 Kumo victoracer (in this pic) I now run the v710
fenders: rolled rear fenders, but not really nessesary
suspension: Ohlin road & track vishnu spec.
Picture is noteworthy because you can see the car at full body lean and how the tires set into the wheel wells. There is some rubbing with the 275's at full steering lock but otherwise works very well.
#101
wheel: 5 Zigen 18/9.5 35mm
tires: Dunlop Direzza DZ101 275/35/18 treadwear 300 last forever on the street FTW
Rub: NONE
spacers: NONE
alignment: Commuter request by San Rafael Mitsubishi lasered to 00.00 camber and 00.00 toe!
front fenders: stock externally; liners trimmed and reshaped by driving for a week while rubbing at lock....NO RUB NOW
rear fenders: rolled lip ( for 200.00 dent wizard fixed the usual warps back to stock)
suspension: Works springs trimmed out back stock KYB's
Soon to be 'used' wheels from Force-fed's old time attack MR wearing Yokohama 275's & my boner stock RS in '05
CIMG0161.jpg?t=1214894907
Dunlop DZ101 Direzza's run narrow so the wrap appears 'stretched' which helps aquire curbrash(gay) & give it that en-vogue, drifter look
Going forward I think a 275/35 or 285/30 Yokohama will be perfect.....latter may rub liners for a week and kiss quarters a bit?
5eebe5e2.jpg?t=1214895088
JANUARYCITYDRIVE006.jpg?t=1214895190
Rub: NONE
spacers: NONE
#102
Diamond Black Volk CE28N 18x9.5 +34 w/ Dunlop Direzza Z1 265/35-18
New wheels finally installed. Required 5mm spacers from ICHIBAUSA to work. Don't let anyone else tell ya differently about the fitment. You WILL need spacers up front and rolled rears.
#103
wheels: Gram Light 57 Max. 18x9.5, 38 offset, 15mm ichiba spacer up front. (your other option is to get 22 offset for fnt, but then you can't rotate tires)
tires: 255/40/18 Azenis
suspension: GP Sports Espilir coilovers, camber: F -2.0, R -1.5
fenders: rolled
BTW: I just discovered that while U turning, the outer edge of my tire was getting sliced. A piece of metal from the frame is hidden behind the mud guard.
I had to peel back my mud guard (rear section) and hammer it down.
fenders: rolled
#104
Wheels: Gram Lights Optimise, Bright Silver
SPECS: 22mm, 21.8lbs - 18x9.5
Suspension: Tein Springs, Stock Shocks
Fenders: Bone Stock - no rolling
Rubbing? None. Front fender liners, tires clear @ full lock. No spacers req. Lots of brake clearance.
255/35/18 Potenza RE050A
