Volks and 245/40 rubbing inside my fender well?
#31
The 40 series tire is approx 653mm in diameter vs stock at 643mm. Thats a tall tire, but very doable. You have a few choices
Leave as is & let the tire burn its way through the liner / Take a heat gun & heat the liner area in question & gently massage it out of the way / Go to the 35 series tire
Heat gun sounds like a good idea. Would it be possible to shim the liner back somehow ?
#33
juat to update.
Heat gun did the trip.
Here are the before pics, you can see where it touched.
After pics, no more rubbing. There is a metal seem behind the plastic that is extremely close but it doesn't touch. I wouldn't autocross with it but on my swift springs no more rubbing.
#35
juat to update.
maxspeed96ct (Sep 28, 2016)
#36
Wish i would have read this sooner. Bought evo X wheels and put Michelin Pilot Sport tires 245 40 and get the rub. Im OCD about things so I guess i have to sell my tires with only 78 miles on them and get 235/40 or 255/35 depending on price and size per tire
anyone in socal looking to buy practically brand new Michelin Pilot Sport 245 40 with 78 miles?? got the paperwork from americas tire
#37
#38
#41
Triple checked and all is wheel, plus car runs straight.
Thats what i thought too about 245/40 since everyone says to just put in EXO X wheels and tires with no prob.
The only difference is that the Michelin 245/40 are a little taller but then I read threads like this one about having probs with 245/40 just like mine and am curious if people just cut their fender liners or not care about rub etc
#42
The heat gun method is good to try for sure. That 40 series tire combined w/a lower ride height is the cause. Curious how low you are? If you dont have a least 2 fingers worth of clearance between the top of the tire & the front fender, you may want to consider cranking up on the coilovers (doing that will change your toe settings!)
#44
Well, the issue boils down the this:
- The 18" wheel w/the 40 series tire
- The +38 offset which positions the tire deep in the well, in contact w/the inner liner at lock positions
FS[MidWest]: White Passenger Fender
Mitchubishievo
Jul 10, 2017 09:02 AM
FS[MidWest]: OEM Ralliart Wheels/Tires/TPMS
Mitchubishievo
For Sale - Wheels / Tires / Suspension / Brakes
Jun 16, 2016 10:34 AM
