AP 5555 caliper & 362mm rotor vs. Endless 6-pot racing caliper & 370mm rotor
I'm going to order a set of front brakes in a few days but I can't make up my mind.
I'm trying to decide whether to go with AP or Endless. I can't find any real tech specs or first hand experience that give me enough information to base my purchase upon.
Can you guys shed some light on this for me?
The other thing to consider is that a lot of the large front BBK's can actually increase your stopping distances by shifting too much bias towards the front. That's why if you don't plan on getting a 4-wheel system it's important to find something that maintains something close to the stock bias. Stoptech is great with this, as they use a universal caliper but alter the piston sizes for each application to fine tune the bias and achieve the shortest possible stopping distances. Alcon also keeps the brake bias close to stock so that's another good option. I don't know a whole lot about AP other than they are very well built and widely used (especially in the UK) but IMO the Endless kit works much better as a 4-wheel kit than if you put it on just the front.
-Dan
-Dan
I think both set up are great. Can't go wrong either way.
But to me, Endless is more bling, bling, and AP is hardcore racer.
Isn't AP own by Brembo, that's what I read on one of the magazine.
i agree with value. even though AP may be used in more racing venues, those venues don't have many, if any, EVO's running so the race experience factor isn't there for them. while braking systems are generally all the same, they stop your car, having actual track time/testing can help to develop a better braking system for a specific application. in this case, an EVO.
with that said, endless or upgraded brembos would be my recommendation.
-Dan
-Dan
Project Mu has an equal setup and so does GREX/ALCON brakes. All three systems are available in multiple rotor setups ie slotted, dimpled, cross drilled, cryo treated, etc. All three also have multiple pad selections for your application.
I would go with plug and play then race. All three of the above can get you there with some bling.
Endless brakes are engineered to maintain brake bais. Hence why they have a 12 piston 6 pad front brake kit for the EVO. Their full brake system 8 piston front 6 piston rear is a ultra nice setup... you can late brake all day long.
http://www.stoptech.com/company_info...hallenge.shtml
Just some food for thought.
-Dan
Maintaining brake bias is a good thing but I get a kick out of how companies use it as a selling point.
You can get a $3 valve and adjust the bias however you want. Turn it one way more fluid/bias to the fronts, turn it the other way more fluid/bias to the rears.
Take the "proper bias" marketing out of the equation and then make your decision. If it were up to me, I'd go with AP over Endless. From what I've seen there's nothing special about Endless, especially considering the price. Matter of fact Endless would be one of the last BBK's on my list..
*edit*
this isn't a shot at Stoptech imparticular, I love Stoptech stuff, and will probly get their 4 wheel kit for the 335i.
*edit*
dj wahid
Sep 28, 2016 07:09 AM
meeklo062704
10
Sep 12, 2016 01:19 PM
apexstrafer
11
Jan 29, 2004 11:21 AM
