ABS delete kit??
Old Jul 4, 2009, 02:59 PM
  #31
4g63girl's Avatar
Originally Posted by DaveK
How does your kit deal with the wiring that the ACD needs from the wheel speed sensors?
Dave
It will NOT work with the ACD unless you can find a way.
Old Sep 10, 2009, 07:00 AM
  #32
Jeovannie's Avatar
back from the dead
How you get rid of the anti lock light after deleting the ABS?
Old Sep 10, 2009, 07:33 AM
  #33
Gordian79's Avatar
Im thinking of abs delete for weight savings.ive done it to all my dsms and roughly shaved off 35lbs.Is there a how to?
Old Sep 10, 2009, 08:12 AM
  #34
MR Turco's Avatar
Originally Posted by Jeovannie
back from the dead
I would assume there is a periphery bit to shut this off in the ROM.
Old Sep 10, 2009, 08:16 AM
  #35
Gordian79's Avatar
Or pull the bulb from cluster.Thats what i did in the dsm days.
Old Sep 10, 2009, 08:27 AM
  #36
Jeovannie's Avatar
Im on AEM
Old Sep 10, 2009, 08:29 AM
  #37
Jeovannie's Avatar
I guess I could try that, pulling the fuse in the front didn't work.
  #38
MR Turco's Avatar
I am wrong anyway you would have to alter the ABS computer which doesn't correspond with the ecu. You could just pull the ABS computer, i am not sure whre it is.
Old Sep 10, 2009, 08:38 AM
  #39
Jeovannie's Avatar
That is #3 and is already gone
Old Sep 10, 2009, 08:42 AM
  #40
MR Turco's Avatar
maybe i am right then, maybe the ABS comp interacts with the ecu for the CEL. If so there is probably an easy fix, it just needs to be changed IF you were running the stock ecu.
Old Sep 10, 2009, 06:43 PM
  #41
GTijoejoe's Avatar
The modulator's computer is attached to the modulator... one unit.
Old Sep 11, 2009, 08:59 PM
  #42
magyar86's Avatar
i will be doing this soon, and i am removing ACD at the same time. should be a blast, luckly there is not a motor and the dash is pulled...
Old Sep 14, 2009, 11:51 AM
  #43
griceiv's Avatar
back from the dead
https://www.evolutionm.net/forums/4646956-post5.html
pin 15 of C-122 to ground.
page 90-116 of the evo9 manual.
Old Nov 10, 2009, 08:41 PM
  #44
yellowevo82's Avatar
anybody who did this mod how is the daily driving now with the abs gone?
Old Jan 4, 2010, 05:59 PM
  #45
38six's Avatar
+1
Quick Reply: ABS delete kit??
