Whiteline Max-C Camber Plates just released!!!
Old Oct 30, 2008, 12:36 PM
  #76
joshesh's Avatar
I PMed you about these, please let me know if you can still get me a set.
Old Oct 30, 2008, 12:59 PM
  #77
GTWORX.com's Avatar
PMed you back.
Old Jun 29, 2009, 05:53 PM
  #78
Thoe99's Avatar
Surely someone's got experience with these plates by now. How are these?
Old Jun 29, 2009, 06:17 PM
  #79
GTWORX.com's Avatar
they've been on backorder for a long time.
call us and ask about the plates we are going to make.
- Andrew
Old Jun 29, 2009, 06:59 PM
  #80
tephra's Avatar
they are good.
the adjustment screws need washers otherwise they go through and dont clear the spring perch...
Old Jun 30, 2009, 02:22 PM
  #81
Z1 Performance's Avatar
we have these in stock if anyone is after a set
Old Jun 21, 2011, 09:14 PM
  #82
Zivman's Avatar
Originally Posted by tephra
well I picked up a set of these (locally was cheaper than importing from the USA)
Anyway's after much stuffing around I was still getting spring binding which was causing a lot of noise in the cabin.
I emailed whiteline AU and they responded saying that they have put this product on hold until a revised product is bought out.
I think the problem is two fold:
1) There is not enough clearance between the bottom camber plate and the top spring perch of the coilovers - easily solved but adding a washer between the supplied spherical bearing adaptor and the perch.
2) I am not sure but I think the spherical bearing may be sticking under load, it spins fine when there is no weight on it - kinda hard to tell thou
So I am waiting for Whiteline to tell me what their plan is...
I have these with KW V3 and have nothing but problems.....
I get a lot of spring binding. I will try the washer and see if that helps. I am thinking the binding may have caused it, but I actually had the shaft of one of my KW coilovers snap... and the other side bend. I had them rebuilt and reinstalled. I am still getting the binding.
pic, because it did happen
also, anyone know if I can get replacement hardware for these? specifically the studs, deep nuts, and spherical bearing adapter
Old Jun 24, 2011, 10:31 PM
  #83
CrunchyMilk's Avatar
That's some pretty gnarly carnage.
As for the hardware, Whiteline should be able to get it for you. Otherwise take some measurements of what you need and just order it from McMaster-Carr
Old Dec 30, 2016, 05:15 PM
  #84
kaj
kaj's Avatar
Wtf how did I get into this thread?!
Jim3142
Jan 31, 2022 08:02 AM
Terror Rising
Jul 28, 2019 06:20 PM
Dallas J
Jan 15, 2017 03:52 PM
guyver858
Dec 31, 2016 04:22 PM
lbcevo
Oct 27, 2016 12:30 AM
Quick Reply: Whiteline Max-C Camber Plates just released!!!
