The Brake Rotor, Pad, Line, Fluid, and Duct Thread
#455
I would buy stock pads , ore Stoptech street pads , ive been using mine fore almost a Year and been driveing , pretty hard , and ive been on some trackdays and there is still a lot to go on them ,
Stoptech price are good
#457
EvoM Community Team
I'm definitely always open to try other pads, I just want to avoid wasting money .
If I had it my way I'd have every pad option and try them all . Let me know how the RB ET500s turn out.
#458
Like i said, it is comparing the CT9A and the CZ4A, but it's mostly the same braking system.
#461
Mostly street - ET300.
I got to use the ET500 some here:
https://www.evolutionm.net/forums/ev...-your-evo.html
After hard laps, they started to go away. But for light use (or fast AX) worked well.
I had a set of early ET500s that I did not like at all. Versions that I've driven since have been good.
#462
I didn't like the trackdays on them. I did one or two weekends on them, and while they did surprisingly well at stopping, not fading, and not wearing down (see above), the noise they generated as they got hotter and hotter simply discouraged any sort of confidence. My instructor got a kick out them. They were the "pissing" in the farting-and-pissing noises my car made every lap Loud loud squealing when pushed to be "race pads." But no fade was amazing for the price of them.
#463
Rear rotors
I'm looking at Tire rack and comparing these two rotors. Are the StopTech comparable to Centric; they appear to be pretty much the same.
Cryo-Stop Premium Rotor - Manufacturer Part #: 120.46065CRY
* Premium black E-coating finish to combat corrosion on the rotor hat and between the cooling vanes
* Cryogenically treated to greatly enhance durability
* Castings have important O.E. details including extractor and set screw holes
* Superior cooling fin designs
* Double disc ground finish
* 100% fully machined finish including rotor hats
* 100% inspected and mill-balanced
* Lateral runout held to 0.002" or less
* Meet or exceed rigid quality specifications, including cooling vane designs
These are the well known Centric Premium
Centric High Carbon Plain 125 Series Rotor - Manufacturer Part #: 125.46064
* Center split castings for increased strength and stability
* 100% inspected and mill-balanced for smooth operation regardless of speed
* Lateral run out held to 0.002” or less
* Meet or exceed rigidity quality specifications, including cooling vane designs
Centric available Cryo treated
High Carbon Plain 125 Series Cryo Treated Rotor - Manufacturer Part #: 125.46065CRY
Centric High Carbon Plain 125 Series Cryo-Treated Rotor Features:
* Cryogenically treated for enhanced durability
I do notice the model number for the StopTech are similar to the non Premium Centric.
Plain 120 Series Rotors
Not sure what they have two different models for the rear:
Special Order
Special Order
#465
I've gotten about the same performance from Winhere as I did with the Centrics. The Chinese are making all of them anymore, seems to be more in the overhead of a company that's the price differential on blanks now. The black doesn't stay black btw.
(Rotors? You want rotors? I've bought two new sets with all the miles I have, plus track duty, they're wear items ultimately, and you don't want them cracking while racing, so they all get retired to DD well before anything untowards happens.)
EDIT: Call OReilly -- my Centrics were pretty cheap there, less than both Tirerack and Partsgeek, at least it was early last summer.
