The Brake Rotor, Pad, Line, Fluid, and Duct Thread
#91
Ok ok, thread revival. I also use PFC 01 pads on my racecar and these are the easiest pads on the disks I've run from all others real race pads I've used. Ferodo, Pagid, Hawk and Mintex. So I assume that the material on the wheels is actually from the pads and not the disks. They are carbon metalic pads afterall. What I use is Welding Anti-Spatter spray and works beatiful. These pads also last the longest of all of them by a big margin. In a rally condition where you're sitting at the time controls for 30+ minutes at times and then start off cold the pads work from the get go, I was impressed. The Ferodo DS3000 were pretty good with that as well but these have more bite and last 3 times longer.
Yes ABS is for sissies, plus it destroys the pads if you're on it all the time and you lose braking efficiency by using it.
#92
I've got an Evo X so would like to confirm that X's fronts are same as 8/9.
Anyone got an X that has some good rear brakes to offer? I want to be able to have DD/street and track pads available to use as appropriate, and the OEM Brembo ones for $300 F and $300 R are not good for either street or track (street -- too pricey; track -- not able to handle the heat).
Would also like to know if any of the 8/9 air dam guides will fit on my X? I have the aero package and the dang Mitsu dealer didn't tell me that guides were more-or-less required with that option. Boneheads.
#94
#95
Please read on which are street pads and which are track pads. A lot of your second Q has be covered here.
Don't know on the glides. They bolt in. So unless there is a location to bolt those to, I would lean towards no.
LookThatsMe - HP+ are NOT track pads - period. You will go over their MOT and it can be very dangerous to your health. I do not recommend anyone run those on a track for their own life is at risk.
#96
Anyone have any pictures of the difference in brake lines that sometimes pop up on Evo 9's? I think I ran into this problem with the SS lines I am trying to install... the part that connects to the hard lines don't look the same as the stock lines. I can get a pic if you guys want.. I just want to make sure that is the issue before I call the company for a different set.
#100
Been running the Raybestos ST43's from Girodisc as a track pad recently. Holy ***** these things are built by the gods of braking. Massive stopping power, great pedal feel with linear increase in torque and they are easy on the rotors. The rotors and pads look like new after a complete day on them.
This is game, set, match for me and track pads. I won't be using anything but ST43's.
I should mention that is in the front, I rock DS2500's out back. Works well.
Installing
After a full day of hard braking.
Installing
#103
On a side note to wear rates, Ferodo DS3000 is the worse pad ever in terms of wear - in rally, they dont even last the whole event. And that's only 100 stage miles... You have to change them half way through!
