Recommend me an Alignment
I've done some research, and wanted to see what some of you will recommend for my specific needs. My evo is a real DD (200 miles a week, driven everywhere sun or shine). However, it also sees the occasional autox event, so I was thinking my alighment, which is stock right now. What can I do to handle better without too much sacrifice on the tires. My current suspension mods are:
Bilstein w/ Works Ride Springs (1 inch drop all around)
Stock 17x8 BBS with 255/40/17 RE-01.
Planning to add the Perrin rear sway this summer.
Lets here it!
Lets here it!
I daily-drive my car all year plus autocross it during the summer.
Somthing like this should be a good starting point for you. I'm on KYB GSR shocks, Swift Sport springs, Whiteline rear anti-sway bar, and a misc. array of chassis braces.
I've been doing alignments on Evos for the last couple years and the best street alignment is
FRONT
left right
-1.5 -1.5 camber
0.0mm 0.0mm toe
REAR
-1.2 -1.2 camber
0.07mm 0.07mm toe
caster is not adjustable on our cars, so I wouldn't worry about it unless one side was 3.2 positive and the other was 2.4 or something varied to almost a degree.
I also wouldn't run 0 toe in the rear. The rear suspension will toe out when it squats, and it makes the car handle weird.
FRONT
left right
-1.5 -1.5 camber
0.0mm 0.0mm toe
REAR
-1.2 -1.2 camber
0.07mm 0.07mm toe
Been daily driving my VIII for the past 30K miles. Went to this alignment spec last August and have been extremely pleased. Very neutral, very tossable, tires show perfectly even wear, ride is terrific, tracks straight, no tram lining, ...
Front Toe: zero
Front Camber: -1.0 deg
Rear Toe: zero
Rear Camber: -0.5 deg
Front Toe: zero
Rear Toe: zero
Front Toe: zero
Rear Toe: zero
Front Toe: zero
Rear Toe: zero
My alignment is the one S2kracka posted from "fetzer tire." This was recommended by GTWORX to use w/ their sprints for 'Street/Road Course" use. These settings were testing by SmikeEvo on the board and perhaps others.
GL...I know mine feel wonderfully neutral, quick turn in and bites really well for my taste!
Thanks for you input.
