I've had it
Old Jul 9, 2009 | 09:03 AM
Mad Gorilla1911's Avatar
I've had it
everything is breaking or has been broken. prevouis owner popped a strut on the right side and only fixed the right side, guessing he didnt get an alignment cuz it pulls mad ballz, so now the left has gone out, i was planning on buying struts, but forget it, i want the strongest somewhat cheapest setup i can do. i will most likely be going with coilovers, unless someone can tell me there setup and prove me otherwise, but what do you think is the toughest coilover. thanks guys.
Old Jul 9, 2009 | 09:21 AM
chu's Avatar
chu
Bilsteins with a good spring (Works, Swift, GT Worx) will do plenty good.
Old Jul 9, 2009 | 10:34 AM
GTWORX.com's Avatar
If you're trying to stay somewhat cheap, i would avoid the somewhat cheap coilovers as they're not generally known for their longevity or reliability. I'd actually avoid coilovers all together. Avoid camber plates too.
Bilsteins with a mild drop or stock spring won't give you trouble. Swift Sports (not spec R) or our GTWorx springs come to mind.
- andrew
Old Jul 9, 2009 | 11:02 AM
thanks for the imput guys
Old Jul 9, 2009 | 12:56 PM
dubcaps's Avatar
that sucks a lot. i feel like if you're going to go for coilovers you should do it right (even if it costs a little more) personally i'd just try to pickup a low mileage stock setup and be done with it.
Old Jul 9, 2009 | 12:59 PM
TheDream's Avatar
What is wrong with the Spec R's?
Old Jul 9, 2009 | 02:40 PM
what im getting
the spec r's a little to performanceywormance for what i will be doing, im going to buy the bilstein struts and the sportmach springs non spec r, the only problem im worried about at this moment is, will it fit my 18x9+30 offset konigs without any fender rollings, i dont know if i want the sportmach springs, or the GTWork, i dont really want to lower it, i like where it is now.
Jcusco407
18
Apr 9, 2013 05:38 PM
Mad_SB
09+ Ralliart Show and Shine
23
May 4, 2012 05:42 PM
naucrx
28
Feb 15, 2008 01:44 PM
digdat
Feb 20, 2005 08:32 PM
shonuffgd
Feb 16, 2004 10:27 PM
