Adjusting Parking Brake at rotors?
Not much to it....just replace the hardware while you're already in there, and adjust the spindle as needed.
I have mine set to GRAB on the first click of the e brake....all preference.
www.EnglishRacing.net they have free shipping on all orders over $100. Tell them David told you to call.
Parking brake answers
Pads I got on ebay centric along with the small parts kit
You have to remove the rotors for the easiest job...replacement is kind of a pain in the *** but easy job once you do it. The adjuster is on the bottom and I replaced all 4 pads and rotors and parking brake pads also.. I did adjust them up to the point where you can get the rotors on without drama. You will know when it's too tight because the rotor won't go on, then back it off a bit. I would suggest the small parts kit because some of your springs may get worn and the pads retainers may break if your not careful. Be patient when doing it. I thought I was going to flip out trying to put the pad retainers on.
Now I have fresh brakes. Slotted rotors and a working parking brake
Slotted rotors, hawk hp plus. Super noisy but crazy stopping power. I can activate abs in the dry very easily.
What is the next step when the rotors have been taken off? Do I have to take off the hub nut and the hub? It looks like it have to go off to get space for working? How do I get it off?
^ Once you remove the rear rotors, the parking brake hardware is right there (someone posted a diagram of the hardware with rotor removed). You can adjust it without taking off the rotor but if you are replacing the hardware, then yes, you must remove the rotor.
You do not need to remove the hub assembly.
POWERSTROKE - Here is the diagram of the rear brake rotors/brake pads removal/install instructions...
This will help you.
Damn...it wont let me attach the pdf because I just attached it to another related thread.. I'll try it another way.
POST #3 in this thread is the diagram I'm referring to.
https://www.evolutionm.net/forums/ev...l#post11184793
This will help you.
the brake slack adjuster which is behind the rubber grommet
which direction expands the brake pads to tighten the lever and compensate for wear
do you use the screwdriver to push in or out?
i did a complete brake overhaul and forgot so i can finish final brake adjustments
it could use a bit more adjusting
For some reason no matter what I do, I can't get the parking brake to engage on the first click. It always goes to about 4 clicks before it starts grabbing.
The car only has 30k miles on it so I doubt the pads could be worn out. I adjusted them so that I had to back it off one turn before the rotors would go back on, yet no change in ebrake level engagement point..... Any suggestions?
I think 4-5 clicks is normal per spec for parking brake lever travel.
CatalystGod
Evo X How Tos / Installations
20
Dec 12, 2016 01:36 AM
MJ23FE
28
Mar 11, 2012 12:54 PM
