Bolt on wheel spacers with extended lugs
Hey All,
I plan on tracking my car more and I'm fixing some damage from my first track day.
I use 20mm bolt-on spacers in the front and I'm putting arp extended studs on.
I assume that I'm supposed to install the extended studs onto the spacers but I want to be sure.
Also, assuming I'm going to be putting the studs on the spacers, how should I go about getting the studs out? Would I be better off using a vice and hammer or taking them to a machine shop?
Thanks!
Thanks!
You mean put the arp on the spacers?
"press out" I don't have a press, is that the only realistic way to get the studs out without damaging the spacers?
Get a ball joint separator tool at Harbor Freight. They cost ~$20, and you can press the current studs out without taking the hub off. It may also work on the bolt-on spacers to get the studs out, but I would not fool with it and get some slid on spacers.
With ARP extended studs you will not need bolt-on spacers ( I think they are bs anyway). Slid the spacer on and you're good.
Bumping this one more time.
After you removed the studs from the bolt on spacers did you take any pictures? If so can you please post them?
I have bolt on 20mm ichiba spacers that im using for my rpf1 race wheels. Id like to remove the built in studs and then run extended arp hardware in the hub. Id like to know how this has worked out for you.
Motorsport-tech sells custom spacers to any thickness you like for about 150 per pair. Very nice quality.
