Tire / Wheel Fitment Questions
Old Jan 10, 2011, 10:11 PM
  #1501
BenJ's Avatar
And for reference, Kaj has a set of 18x10's +22 with 255's mounted on his evo. Fender rolling and some camber looks to be all he needed and he has room to spare. I have a set of 18x10 +38 wheels with 265 AD08's that I'm going to be mounting at the end of this month. With the 38 offset I have to run a 10mm spacer up front, but other then that the only fender mods that I am foreseeing are heavy rolling.
Old Jan 10, 2011, 10:12 PM
  #1502
Evoluvin's Avatar
Originally Posted by BenJ
spacers would be dependent on the style of wheel, but with that offset, there is a good chance that you wouldn't need any spacers.
Here they are. I was told a 15mm or 25mm spacer would be needed.
Thanks for the help!
Old Jan 10, 2011, 10:15 PM
  #1503
BenJ's Avatar
Originally Posted by thai4g63
Just wondering if 18x10 +18 Work Emotion XD9 wheels will clear the stock brakes? And what is a good tire size that will go with it?
I think that you have to run a 10mm spacer with the xd9 regardless of the offset due to the spoke design. Not 100% sure on that though. I do know that I had to run a 10mm spacer on my 18x10 +38 xd9's in the front. Hope that helps
Old Jan 10, 2011, 10:18 PM
  #1504
BenJ's Avatar
That would be a tough wheel to fit without a widebody. Reason being that with a 15 or 25mm spacer, you will be running the equivalent of a +10 or 0 wheel....which coupled with a 10" wide wheel is getting aggressive for an evo X, let alone a VIII or IX. My recommendation would be to find another set of wheels.
Old Jan 10, 2011, 10:22 PM
  #1505
Evoluvin's Avatar
Ok thanks man... Ill keep looking.
Old Jan 12, 2011, 01:59 AM
  #1506
CAM 6's Avatar
Looking for 182 rims with BIG offset
As above what wheels are available in large offsets. 9X18" rims with offsets of +8 to +15 ??
Could anyone point me in the right direction of wheel makers or suppliers.
Reason....is that im going wider front and rear arches Front possible 15mm wider and rears something like 10mm wider.
Thanks
Craig
Old Jan 13, 2011, 01:16 PM
  #1507
Chris n Rabecca's Avatar
Question Konig Lace Rims
I was wondering if anybody on these forums is running Konig Lace Wheels. I was getting Some tires on my other car (06 GTO) the other day and Saw some at discount tire and figured they would look good on my 03 Tarmac Black Evo. Just a thought.
here is a link to the rims:
http://www.discounttiredirect.com/direct/wheels/konig/product/submitProductSize.do;jsessionid=1npHNvrTzH7Z2DgzTM N6blgp2Vndtn103PXv4VHTmT6w7Jnh6ynf8h2QTjzQgjh1dYk6 Tb2ngTkCPrX01dP4hN4v1Cb9dGWL3yLsb7y4lyZS2sZ68TjGD8 MLLMtg2TPs!-744608417!-258112936?pc=23397&typ=Truck&tmn=Lace
thanks
Old Jan 13, 2011, 03:23 PM
  #1508
v8<turbo4's Avatar
OZ ultraleggera Rims wont fit my car... Why? 18X8.5
hey so i bought some OZ ultraleggera rims they are 18X8.5 if i remember correctly and a 35MM offset
Went to put them on the car and every thing seemed fine then i realized they rub the brake calibers.
also i went to use my stock lug nutz and they dont fit in the set holes for the rims.
I called tire rack and they said they dont sell spacers for them.
Does anyone know what i need to make these rims fit?
Also what lug nuts i should buy for it to fit.
I have been searching all over and i cant figure it out
if you guys could send me a link on what to buy it would be very appreciated.
Thanks
Ian T
Old Jan 13, 2011, 03:39 PM
  #1509
evoboi005's Avatar
Thanks
Ian T
you need after market lug nuts everyone sells them. they different from oem type lugs ...there are a couple different spacers listed on this site. You need to figure out how much space you need for the wheels to clear the breaks.
Old Jan 13, 2011, 03:56 PM
  #1510
v8<turbo4's Avatar
how do i figured out how much space i need? also do all aftermarket lugz have the same thread pattern?
Old Jan 13, 2011, 04:04 PM
  #1511
Ryan.Kauz's Avatar
1) you can do some of this searching for yourself, the lug nut question is very basic (i'm trying to teach you how to answer your questions quicker than relying on a forum as you seem to need alot of input.
2) Google is your friend. "Brake caliper clearance".... first returned hit:
http://www.buybrakes.com/brembo/caliper-clearance.html
3) wheel spacers: Touge Factory (a sponsor on this forum) can assist you. Will let you find them in the vendor section as part of your forum navigation training!
Old Jan 13, 2011, 04:30 PM
  #1512
Neal@tirerack's Avatar
Doesn't sound like an EVO fitment being 18x8.5" wide. Might be the odd width causing an issue.
Old Jan 13, 2011, 06:57 PM
  #1513
ssg_petty_210's Avatar
Does anyone have a pic of a set of 17x9.5 +25 Rota Grids? I cant find any.
Old Jan 13, 2011, 07:15 PM
  #1514
Vivid Racing's Avatar
they should look good, is your car lowered?
we also sell them http://www.vividracing.com/catalog/k...6332_6352.html
-anthony
Old Jan 13, 2011, 07:19 PM
  #1515
one4's Avatar
Quick Reply: Tire / Wheel Fitment Questions
